Old 08-22-2010, 07:18 PM
Air control valve??
Melis's car is giving a code 24 along with rough idling at times. Code 24 is air control valve. Is that the one that mounts to the bottom/front of the throttle body??
Old 08-22-2010, 08:48 PM
sowise sowise is offline
Re: Air control valve??
If it is the Bypass air control valve it is supposed to be just below where the throttle body and intake manifold meet. If it is for the Aux Air Control Valve left rear of the water pipe.
Old 08-22-2010, 11:43 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Its the bypass air control valve, the one under the TB. Same as an IAC valve just differently phrased.
Old 08-23-2010, 06:56 AM
macadamianut macadamianut is offline
Try cleaning it first, with MAF cleaner. Also, new gaskets for the By-Pass air and TB are cheap through subaruparts . com. Since you would be removing both.
Mac
__________________________________
1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and .....
1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs
