Can you use any year transmission
Can you use any SVX transmission from any year car....like a 92 or 94 in a 96. as a replacement?
1996 Black, 134,000 KM, with Custom Stainless from Headers to Stebro, 17" Wheels, Michelin Pilot Sport PS2 225/45/17 Cold Air Intake. Pioneer AVIC D3 GPS/Video/Sound/Sirius/Bluetooth/USB Koni struts/ground control coilovers Stainless steel brake lines K&N filter, custom front grill H.I.D low beams 5000k 35w, H.I.D fog/driving 4500k 35w Clear front and corner lens |
Re: Can you use any year transmission
Any year SVX transmission is a direct replacement,
Thank you very much.
Id try for a later year if possible... stay away from the 92's.
I found one in New Hampshire for $400.00, with 80k miles on it, but in "excellent condition". I just need to get it brought to Toronto, still trying to find out what year car it's from.
Just in case you aren't aware I have very affordable rebuilt and upgraded transmissions. Last time I shipped one to canada freight was about $500.
http://www.ecutune.com/4eat.htm |
Not to nitpick but just to avoid confusion to anyone who would see this, even though it would appear obvious, a FWD transmission can only be used in an AWD car if you choose you don't want AWD anymore.
Actually you can bolt all the AWD parts and wiring into a FWD tranny to make it an AWD, but they run a different final drive ratio, so you'd also need to change out the rear diff...
Very true, but then it isn't so "direct"
In talking to my son, he told me the 4.44 would make the car faster? Would I also have to change the rear diff? The tranny in NH is from a 92, think I'll pass on it as it will go very soon, my 92 went through 3 of them in 450,000km, it's now a 5 speed.
If you get a transmission with anything other than the SVX OE 3.545 gear ratio you would have to get a rear differential set up with the matching gear ratio. I personally prefer the OE 3.545 gear ratio. When coupled with one of my performance transmisison control units (TCU) most people agree. The SVX doesn't really need a higher gear ratio to get better acceleration; it needs the better shift maps I put in the performance TCUs. The higher gear ratio is really only beneficial for drag racing.
In their stock form the non SVX transmissions have a couple clutch packs which are weaker than what's in the SVX transmission; however, when ordered from me the transmission will be upgraded to the same much stronger than original equipment setup no matter what the gear ratio. My preference and my advice is to stay with the original 3.545 gear ratio and get a performance TCU to match. Quote:
Tom |
Probably should mention that you should avoid the JDM transmissions.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
