power steering issue
I started my car the other day and ever since my power steering seems to be half working driving and shifting lanes isnt bad a little stiff but at lower speeds like in a parking lot its WAYYY stiffer like it just wont work.
also get a whine when turning the wheel any clue?
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
Re: power steering issue
How old are your belts?
You may want to check out the crank pulley, look if it's showing any signs of separation. Paint a line on it across the layers, after it runs, see if the line is still in one piece.
first off check your fluid level (remove the screen).If it's low it could be leaking from a hose or your steering rack. If all that's ok the winning could be the power steering pump.
level's fine we're thinking its the pump, i'm thinking to try flushing the lines but i dont think that will do much will it?
I'm guessing the O-ring in the pump tank. Look in the how-to docs to see how it is done. I wouldn't do anything before I check that out. It makes the steering stiff, makes noise, and lots of other problems. I would bet that is the problem. Good luck.
would a faulty o-ring really cause that kind of an issue with the steering?
wow... talk about the straw that broke the camel's back lol
The first symptom is usually a high pitched sort of squeak/wine at full lock or when the pump is delivering full pressure. This appears to result from a valve chattering, but as I understand it this has not been absolutely confirmed. The good thing is that it is a very easy and cheap fix and certainly should be tried before embarking on anything more expensive.
Also, don't overlook the obvious.
Make sure the belt is in good condition and that it's tight enough - change it if in doubt. The belt is under more load in a parking lot then when driving. |
I had the tight steering and whine at slow speeds too. I replaced the o-ring(put one in as mine was completely gone), and no more problems. Works great now.
1992 SVX LS-L: For sale 1995 Lexus SC400- Lexta Z |
It is hard to believe that such a little part (O-Ring) could cause so much problems. The good thing as Trevor said - it is cheap and easy to replace and the best thing to replace before doing anything that is more expensive. I have seen some very bad problems fixed by doing this.
Thread Tools | |
Display Modes | |
