Old 07-03-2010, 07:28 AM
alia176 alia176 is offline
Removal of the annoying buzzer
I finally got around to this project while doing A/C work. I find the door chime buzzer (that alerts you when the key is in the ignition while the door is open) ever so annoying and it was time for removal...after 10 years of ownership I often work on the vehicle with the door open and key in the ignition and end up doing this to all of my vehicles; don't quite know why it took so long to do this on this vehicle!
This unit is located behind the glove box and mounted just below the round structural tubing. The CC ECU is slightly above and to the left of this unit. The unit comes apart pretty easily and snaps back together just as easily.
Removal of the round buzzer requires the use of a solder. Pretty easy.
Let me know if you have any questions.
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 07-03-2010, 11:19 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Removal of the annoying buzzer
You can also cut the wire that goes to the ignition like I did also.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 12-28-2010, 09:03 PM
Anyone know where that little chime box is in a '94? I'm not finding it in the same spot.
Old 01-08-2011, 03:23 PM
Found it. It sits above the glove box where the security modules are in the 92s and 93s.
