Momo steering wheel with airbags that work???
I did some searching because I saw a lot of members that had momo's that they didn't have the airbags functioning on them.
I found this on ebay and was wondering if, since it's the same generation if the plugs would be the same and I could get the airbags to work??? http://cgi.ebay.com/ebaymotors/JDM-S...ht_4051wt_1165 any thoughts??? |
Re: Momo steering wheel with airbags that work???
Its not a matter of just the plugs being the same, but also the voltage that is sent to the airbag unit to deploy it as well as the constant signal that tells the airbag computer that everything is in proper order.
Even then, you still end up with an airbag that was designed for a different car with different dimensions. |
I might have an idea Johny. PM me...
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. Last edited by SilverSpear; 04-30-2010 at 03:13 AM. |
PM me, I want to know too
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Just post it! We all want to know!
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
I've got an idea, but I don't know if it would work or not. Just get an airbag control unit from the same car. If the sensors are different then get those too. As long as the overall layout is the same with regard to sensor positions, then the only issue would be in whether the airbag controllers communicate with anything in a way that would cause problems.
That will not work. I have ordered several momo wheels from Japan and tried them. None use the same plug orientation.
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
my svx is airbag free
Also, switching over the entire air bag computers, sensors, wiring, etc out of another car will probably not work either. The air bag computer recieves input reguarding the speed of the vehicle so that they never deploy below certain speeds.
If the speed is sent to it as a pulse, couldn't that be accounted for? If it's data, then that might be a problem. Also, if the two cars require different speed thresholds.
Also, that makes me wonder. A few weeks ago, my speed sensor (the one that is reported to the speedometer) broke and I replaced it quickly. In the meantime, having no speed, would the airbag have worked at all? I think the problem could probably be solved with enough electronics expertise. And maybe someone could even reprogram the airbag controller to make it work just right.
Not saying its not possible, just that its not going to be as simple as what most people would automatically think, that's all. Also, I personally wouldn't be f*****g around with different airbags.... Don't need a "bomb" going off improperly. |
I know the airbag technology is popular for safety but other than maybe turning of an airbag light I don't really see the point in making a different one work. I know people swear by them and I do concede they improve your chances but there are also downsides to them as well. Wear a seat belt and drive defensively. Plus I would put our SVX up agains a prius anyday.
Thread Tools | |
Display Modes | |
