Old 07-07-2009, 08:57 PM
the_paynter the_paynter is offline
How do you remove the SVX rear bumper
Well ive basically removed 100000 bolts and I STILL cant get the rear bumper cover off. Is there a trick to it or something? Some hidden bolts? I have no idea someone please help and maybe take a picture and circle where they are, im trying to to prep this for paint and I have a new bumper as my stock one someone tried to fix with bondo (FAIL)
PLEASE help!
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 07-07-2009, 09:04 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: How do you remove the SVX rear bumper
Well take the carpet out and you'll see 4 big grommet plugs, 2 on each side. Remove the caps and undo the 4 bolts. After that pull the side trim back a little bit and remove the screws holding the side of the bumper on. After that their might be a couple small screws bolts on the bottom, its been too long since I did this so it's a little hazy. Once all bolts/screws are removed tilt the bumper up and release it from the hooks and your done.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 07-07-2009, 09:24 PM
gahhhhh.... thank you sir.
Crazy SVX and sticking bolts in dumb places
Old 07-07-2009, 09:38 PM
Elliott's Avatar
Elliott Elliott is offline
A lot of Subarus have bumper mounts like that. We've got a '92 Loyale in the shop now that is getting clipped, those bumper brackets become really fun when the car is wrecked.
Old 07-07-2009, 09:56 PM
Really eh? See Impreza and legacys just have 4 big bolts under the car, MUCH easier
Old 07-07-2009, 10:03 PM
Elliott's Avatar
The Loyale might be like that in the rear, that end isn't wrecked so I didn't check, but the front is like the SVX, except the bolts are on the side of the instead of the top.
Old 07-07-2009, 11:53 PM
Gamesy's Avatar
Gamesy Gamesy is offline
ya i'm not looking forward to taking my front bumper off to repaint lol
Old 07-08-2009, 07:42 AM
Front was actually pretty easy. I got the front off in about 15 mins with a phillips, a 10mm socket wrench, 10mm wrench and a flat head. Did I mention it was mt first time trying and I was in grass with no jack haha
Old 07-08-2009, 09:55 AM
Elliott's Avatar
Did you pull the bumper and the bumper cover off together? Pulling them both off together is the easy way. If I remember right, there is a 10mm bolt on each side where it meets the fender by the wheel well and 4 17mm bolts under the hood.
Old 07-08-2009, 10:05 AM
No I took off just the cover. 2 at the fenders, 10 under the headlights/grill, 4 in the air dam, only 4 that need to be undone under the bumper, and 2 pop-clips.
Old 07-08-2009, 10:34 AM
Elliott's Avatar
If you remove it all together, the headlights don't have to come out.
