Old 05-23-2009, 06:32 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Thinned harness.....DONE! :)
Well after a week of poking wire by wire and going by the meager diagrams online I finally finished thinning out the PCM harness. Now I can drop the Eg33 into my WRX and have just the necessary wiring required to run the motor(and have output for dash tach).
This is what you end up with:
Here's a box of all the nice colored wire that I'm saving for other uses(box is 8x6x6 inches) and a plastic grocery bag full of all the unused and clipped harness connectors. the bag probably weighs in around 8-10lbs!!!
Now that this is done I can move onto the fun stuff....actually putting it in and making the SS headers to clear the WRX subframe and full undertray/skidplate
Old 05-23-2009, 08:27 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Thinned harness.....DONE! :)
Wow! Did you happen to draw out the resulting wiring diagram?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-23-2009, 10:23 PM
Boxersix's Avatar
Haha, no i didn't. I started by hacking off every connector that didn't go to the PCM or engine harness, then weeded out the remainder of the wires and clips that were not required including the scan ports/select monitor port. The system is simple enough to diagnose even without codes + scanner. and isn't needed.
Old 05-23-2009, 10:45 PM
SVXRide's Avatar
Have you had time to hook it back up and make sure the engine starts/runs?
-Bill
Old 05-24-2009, 07:38 AM
Boxersix's Avatar
-Bill
Not yet. The engine is still sitting in the stand waiting to go in. I was waiting for the Sti clutch/FW to arrive.
