Old 05-12-2009, 11:23 AM
canbritsvx's Avatar
canbritsvx canbritsvx is offline
Remote entry?
Hi all, newbie.
92 teal green lsl 137000km (82000ish miles) 5 speed
Just a few quick questions to start with.
1. My door/ignition key does not fit the trunk, is that normal?
2. Remote entry, i received just a key, how would i know if the car is equipped with remote entry?
3. Small cosmetics such as seat levers, is there a good source?
Many thanks
Glad to join the elite :-)
Clive
Old 05-12-2009, 10:44 PM
Onetrack's Avatar
Onetrack Onetrack is offline
Send a message via ICQ to Onetrack Send a message via AIM to Onetrack Send a message via MSN to Onetrack Send a message via Skype™ to Onetrack
Re: Remote entry?
Hey if your car has a ' security ' button just to the left of the steering column, then it has a factory alarm system - if you like, I bought a fob for the 92-95 svx that I can't use as I never checked for this - if you want it, pm me and i'll send it to ya.
my door/ignition key also does not work in the trunk, perhaps the key that you and i have are valet keys?
I have to open my trunk using a lever on the floor
Old 05-13-2009, 01:00 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Re: Remote entry?
Did Canadian SVXs get the keyless entry/security system?
Even if you have the Security button on the dash, it's still possible that the module was removed or has died (which is all too common).
Does your key work in the glovebox? If it's a Valet, that should not work either. Exterior locks (trunk or door) can fail due to dirt/corrosion too).
Is your key the SVX OEM key? If so it should have either X or Y below the key number. X is driver's, Y is valet.
David C.
Old 05-13-2009, 05:35 AM
Re: Remote entry?
Hello to a fellow Ottawan.
There's 2 SVX at a junk yard on Vanier Road in Aylmer 819-682-3525.
Old 05-13-2009, 07:37 AM
canbritsvx's Avatar
Re: Remote entry?
Thanks for the help guys i will ceck the key, no i do not have the security button, does that mean i dont have remote entry?
Old 05-13-2009, 05:33 PM
Re: Remote entry?
That would be correct then. Most Canadian SVXi did not come with the security system.
Old 05-13-2009, 06:09 PM
Manarius's Avatar
Manarius Manarius is offline
Re: Remote entry?
When I first got my car, I thought I had a valet key because I couldn't open the trunk either. A little white lithium later I figured out I had a regular key because now my trunk lock could be opened with the key. I find that the SVX's locks are quick to get a little resistant if not used regularly. The locks on my doors are slowly becoming a little harder to open because I don't use them regularly.
-Jason
-Obi Wan Kenobi
Old 05-14-2009, 06:34 AM
canbritsvx's Avatar
Re: Remote entry?
Well i cannot lock the glove box either, so its probably a valet key, i will order a new one.
Thanks
Old 05-14-2009, 06:36 AM
canbritsvx's Avatar
Re: Remote entry?
Thanks Blacky i will be visiting for parts. Are they yours ? Do you know if the interior trims are gray?
Old 05-14-2009, 06:54 AM
AyeJaye's Avatar
AyeJaye AyeJaye is offline
Re: Remote entry?
My key has never worked in my trunk either. I'll have to do some fidgeting and see if it just needs cleaned out.
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle
06 Hyundai Sonata GLS, 77K miles
Old 05-14-2009, 07:03 AM
Re: Remote entry?
The locks in the doors easily get siezed from never being used. Also the keys do start to wear away and so they will work fine in the ignition as the tumblers in there will start to wear or adjust over time and usage. The trunk and doors get used far less and so the tumblers are still very close to new and so the worn key will not work so great.
For instance, my key I received with the car I need to fidget around to get the trunk to open but the key I had cut by key number works perfectly fine every time. Also the lock in my driver's door is seized pretty bad and so the new key does work but takes some effort. The old key I am too afraid to break off and so have never really tried. Both unlock the passenger door just fine though...
Old 05-14-2009, 08:58 AM
Green1995SVX's Avatar
Re: Remote entry?
If your key has a Y stamped into the metal part, it's a valet key. If it has an X, it's a regular key.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 05-14-2009, 03:08 PM
Mistoffeles Mistoffeles is offline
Re: Remote entry?
Mine didn't, I had an aftermarket alarm/keyless entry/remote starter/stereo installed immediately (the factory CD didn't work and the 15 year old speakers were not acceptable by modern standards).
Good to know, I always wondered why one key worked and the other didn't. I made 2 copies off the Y key and got all pissed off at the keymaker because they didn't work in the trunk or glovebox. he didn't know about the X and Y either.
Old 05-14-2009, 04:41 PM
Re: Remote entry?
Not mine, if they were they'd still be in my yard with the dead Outback and other assorted motorized stuff.
The interiors are both grey. Ones silver and the other is blue, I think.
Old 05-14-2009, 10:22 PM
AyeJaye's Avatar
Re: Remote entry?
Well I'll be damned... That explains a lot. I'll have to check my spare and see if its stamped with an X.
