Old 07-10-2002, 10:59 AM
kuoh kuoh is offline
CDA and subaruparts.com
Just fired off the following parts list to cdasubaru.com to see what kind of pricing they can give me. Subaruparts.com online parts gave me the following, but I couldn't find an e-mail address to send an inquiry for better pricing nor did their web support form work. I wonder what else I should tack on to this already too expensive list?
subaruparts.com pricing
Subtotal: $1,658.68
S/H: $165.87
Grand Total: $1,824.55 OUCH!
x 2 806732150 Cam oil seal 32x45x8
13028AA120 Timing belt
x 3 24233AA330 Sparkplug wire clip
24233AA340 sparkplug wire clip
13272AA031 Valve cover gasket (driver)
13293AA011 Valve cover gasket (driver)
13293AA020 Valve cover gasket (driver)
x 4 800706630 Valve cover bolt-6x39.3x10
x 4 800706620 Valve cover bolt-6x29.3x10
21111AA033 Water Pump
x 2 01040625A Thermostat bolt
21116AA020 Water pump seal
21114AA050 Water pump gasket
x 2 20326AA120 Strut dust seal - front
x 2 023512006 Strut self lock nut - front
x 6 023510006 Strut self lock nut - front
x 2 20320PA011 Strut mount - front
x 2 20326AA000 Strut spacer - front
x 2 20325PA000 Strut rubber stabilizer upper - front
x 2 20322PA000 Strut dust cover - front
x 2 20321PA010 Strut helper - front
x 2 20325PA100 Strut rubber stablizer lower - front
20311PA001 Strut - passenger - front
20311PA011 Strut - driver - front
x 2 20540AA090 Strut bolt - front
x 2 20540PA010 Strut bolt - front
x 4 20550AA010 Strut nut - front
26257PA000 Brake shoe passenger - rear
x 2 26257PA020 Brake shoe - use 26298PA000
26257PA010 Brake shoe - pt370697 use 26298PA???
x 2 023512006 Strut self lock nut - rear
x 2 031012006 Strut washer - rear
x 6 902350013 Strut self lock nut - rear
x 2 20370PA000 Strut rubber seat upper - rear
x 2 20361PA020 Strut guide - rear
x 2 20372PA010 Strut dust cover - rear
x 2 20371PA000 Strut helper - rear
x 2 20370PA010 Strut rubber seat lower - rear
20360PA001 Strut passenger - rear
20360PA011 Strut driver - rear
x 4 20540PA010 Strut bolt - rear
x 4 20550AA010 Strut nut - rear
062610110 PS O-ring
45167PA000 Radiator hose upper
45167PA020 Radiator hose lower
x 2 091748004 Radiator hose clamp
x 2 22690AA180 Oxygen sensor
57521PA000 Trunk strut passenger
57521PA010 Trunk strut driver
x 7 57719AA020 Undercover bolts
x 4 62310PA000 Window stabilizer - out
x 2 62320PA000 Window stabilizer - in - passenger
x 2 62320PA010 Window stabilizer - in - driver
86640AC040 Rear washer nozzle
x 4 13230AA153 Valve lash adjuster
x 16 13210AA020 Collet Valve
Old 07-10-2002, 08:35 PM
svxpert svxpert is offline
parts
P.M.'ed you.
Old 07-12-2002, 09:19 AM
Lowered SVX
jesus.....
are you rebuilding the whole damn car??
"Too much fun to drive!"
Old 07-12-2002, 09:25 AM
I'd like to rebuild the whole car, but for now, I'll just settle for most of it. The bad news is, I might have to put all this off and get the tranny done first. 3rd gear is slipping more and more.
KuoH
Old 07-12-2002, 10:34 AM
Lowered SVX
i have been there and done that.
i finally have my svx running good again so now i am focusing more on cosmetic stuff. powdercoating my calipers, getting the car painted, the interior redone...etc.
best of luck.
