Old 04-06-2008, 10:08 PM
wold racing wold racing is offline
Diff noise a bit better
I drove the SVX to MN form FL with the fuse in so that it stayed in front drive only. I took the fuse back out when I got to MN and the rear diff noise seems to be a bit better.... No noise in a straight line.... Turning right or left while going forward, there is very little noise.... Turning right or left while going backwards and you can hear clunking.... Noise just like you are pushing a race car while turning with a LSD or locked rear end ..
I was looking at the manuals and it shows the diff uses typical gear lube on the final drive side of the diff and that the LSD side is "sealed", whatever that means... If it is sealed, what is the lubricant and how does it stay sealed??
Has anybody seen a good article on how the rear diff works and any ideas on why
Old 04-16-2008, 05:53 PM
processengr's Avatar
Hi,
Does the car have the retrofit by Subaru transmission oil filter? If not, it is well worth it to try this, take off the transmission cooler lines, and blow compressed air through the cooling circuit in reverse, to blow out the transmission cooler screen/strainer, built into the radiator.
Debris from clutch mat'l breaking down can clog the screen affecting operation of transfer clutches and eventually burning out transmission.
The Subaru retrofit filter instructions advise exactly this reverse flushing of cooler circuit, which is why this is relevant.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
