Old 02-28-2008, 06:26 PM
snofrek's Avatar
snofrek snofrek is offline
SubyFREAK
Send a message via MSN to snofrek
Question 4.44 question?
will the torque coverter 96-97 4.44 transaxle bolt up to my '92 flex plate? or do i need something special?
Old 02-28-2008, 06:27 PM
yes... do a search and read a lot.... Its all out there
Old 02-28-2008, 06:41 PM
snofrek's Avatar
SubyFREAK
thanx man!
Old 03-10-2008, 08:32 PM
snofrek's Avatar
SubyFREAK
Question
another question..... on the rear diff, when i swap out the parts into mine, i cant remember what its called but do i have to shim anything and try to align up anything or is it all one piece and it will be an easy swap, i think its the ring and pinion, do i have to align that up when i put it in to the rear diff chassis, or is it all bolted up into one piece already and i dont have to worry about that?
Old 03-10-2008, 08:47 PM
Boosted's Avatar
Boosted Boosted is offline
You will have to disassemble the unit, swap the ring gears, and then reinstall it all in the new diff case. It will have to be shimmed for the correct fit, but you will probably be able to use your old shims.
'92 SVX LS-L - 4.44 Tranny
'67 VW Fastback - Undergoing restoration/ej257 conversion.
Old 03-10-2008, 08:50 PM
snofrek's Avatar
SubyFREAK
ok, so would it be safe to do it myself or should i take it to a shop?
