Old 02-25-2008, 03:50 PM
kis86's Avatar
kis86 kis86 is offline
replacing something or another
Send a message via MSN to kis86
CEL on, but no blinky light?
My CEL has been on in my '95 for a while now...decided to check codes using the instructions in the how-to, but the power light doesn't blink... it just sits there solid.
What am I doing wrong??
Old 02-25-2008, 04:28 PM
Manarius's Avatar
Manarius Manarius is offline
The check engine light is the one that blinks, not the power light. It blinks in sequences of long and short blinks.
-Jason
-Obi Wan Kenobi
Old 02-25-2008, 05:43 PM
kis86's Avatar
lol
woops! lol my mistake, but no cel light blinking either...just solid, as all the other lights are
Old 02-25-2008, 05:50 PM
Let's straighten things out. There are two different self check procedures, one to check ECU (engine) codes, the other to check TCU (transmission codes).
ECU - If your CEL light come on, you want to run this test. You use the blue test leads and the black plug behind the kick panel under the fuse box. It flashes the CEL.
TCU - If your Power light flashes at start up, you want to run this test. You use the ignition switch and shift selector to enter the "read" mode. It flashes the power light.
Old 02-25-2008, 05:57 PM
kis86's Avatar
Yep!
Yep! I'm checking engine codes, using the blue wire into the second from left hole in the black connector...and it's facing the correct way. In fact, I have checked codes before with success...it's just not working now unfortunately this time, I don't think I'm doing something wrong. Thanks for your help guys!
Old 02-26-2008, 10:58 AM
kis86's Avatar
Any reason there wouldn't be any codes if the cel is on?
Old 03-03-2008, 04:31 PM
kis86's Avatar
bump
any ideas? Please help!
Old 03-03-2008, 04:46 PM
you have the connector upside down... or you are not using the small black connector??
Old 03-04-2008, 09:58 AM
kis86's Avatar
Yep, using the black one...notch side up I've tried multiple times to read the instructions exactly, just in case I was doing something incorrectly, but it seems pretty simple!
The only thing I can think of is...my cel is on 90% of the time, off 10% of the time...will it only work if the cel is on at the time of engine shut off?
Old 03-04-2008, 11:18 AM
there are two black connectors in there... Make sure you are using the small one
Old 03-04-2008, 11:25 AM
dcarrb dcarrb is offline
No, you can check for stored codes even if you've never had the CEL come on.
dcb
Old 03-04-2008, 01:47 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Do you have a laptop and a Select Monitor Adapter by any chance? Are you any kind of computer geek?
There is a way to read codes directly from the ECU memory and maybe pick up a few clues.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-04-2008, 07:26 PM
kis86's Avatar
Hahaha I feel so awesome
I was using the large connector. The small one was tucked wayyy inside and I didn't realize it was even there. Thank you all for your help, and thanks Tom for pointing out the obvious since I couldn't see it myself
Old 03-05-2008, 01:25 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
such a thing exists? where do i get one?
- John
Old 03-05-2008, 01:49 PM
b3lha's Avatar
Phil & Belha
You have to build it yourself, but it's quite easy to do. The preferred method is to buy a USB to 5v TTL cable and then add a few extra components to work around what we call "the 92 problem".
http://www.subaru-svx.net/forum/showthread.php?t=38685
http://www.alcyone.org.uk/ssm
I'm surprised you haven't seen posts about this before.
