Old 02-21-2008, 10:11 PM
cruisen_15's Avatar
fans not working
ok so back when i hit that curb of "doom", i relized the metal wire running across the radiator got tangled in the fans.. when i clipped off the wire and put the assembly back together, but now they arnt working.... i let it idle for 45 mins and when it got past average temp it kept climbing and the fans didnt even turn on, im not sure if the motors in the fans are bad now or just the relays for the fans, any ideas?
Old 02-21-2008, 10:32 PM
Use a test light or meter to check for voltage at the fan plug. The fans turn on if you set the HVAC to auto, so you don't have to wait for it to get warm.
Old 02-21-2008, 10:40 PM
Hondasucks's Avatar
Subaru Technician
Check the fuse, if the wiring got tangled, chances are something shorted out.
1986 VW Jetta
Old 02-21-2008, 10:53 PM
I don't know what wire you are talking about, but you 'clipped it'.
If I read this as you cut a wire and are now having issues. So then just un-do what you did to the wire. This seems to obvious so what am I missing here.
blk 92' LSL w/ average mods
Old 02-21-2008, 11:23 PM
cruisen_15's Avatar
its the metal cable running around the radiator its self, its pritty thick and the fans got tangeld in it... the fans wont turn on with the a/c auto on...
Old 02-21-2008, 11:26 PM
cruisen_15's Avatar
am i looking to see if the "fuse" or "relay" got burnt out? is ebay the best place to get new relays?
Old 02-22-2008, 01:25 AM
kwren's Avatar
kwren kwren is offline
best place to get a new relay...
Which you undoubtedly don't need... is the Subaru dealer. Tacoma subaru is subaruparts.com and if you go over and tell them you want to see the web people, they will give you a good price.
Ebay probably will not have a "new" relay. You might need a new fuse. The price from ebay + shipping and lost time not having the use of your car would probably not work well. Then there is always the chance that the relay you bid on might not last as long ar your present relay will last for you.
Like YourConfused previously said, just undo the damage you did and you should be good!
Old 02-22-2008, 07:22 AM
Wikedjuggalo's Avatar
Rebuilding
It seems you might have burned your motors up. I'd say if you got it tangled and they were trying to turn and weren't able to move could have burned the motor up? I'm not sure but something to do is get another fan or 2 (I'm sure having them wont hurt) and test them by plugging them up and turning a/c on.
Old 02-22-2008, 07:48 AM
cruisen_15's Avatar
i checked and relays work from 93-97 impreza. 90-98 legacys, so im going to take the relays off my legacy and see if it works, im confused, is a relay a fuse or is a fuse a relay? you guys keep switching between the two in your post and now im very confused!!
Old 02-22-2008, 03:49 PM
edmsvx's Avatar
edmsvx edmsvx is offline
Check AC fuse
Check the 10 amp AC fuse in the engine compartment fuse box. My fans stopped working after this fuse went.
1992 (JDM) CXD Ebony Pearl 90K km written off hail damage
1996 (CDN) Lsi, Polo Green, 296,000 km
2009 Legacy Spec B
Old 02-22-2008, 06:40 PM
cruisen_15's Avatar
both the 25 amp fuse's were blown, replaced them and bingo, the fans worked fine ,
i recieved my A arm 2 weeks ago and right after that a guy calls from new york, and im in washington. he sais he recieved my tie rods. i was so mad because i baught the tie rods from a place in california and they sent it to new york!!! the dealer said he sent it back but i have not seen it and its been 2 weeks now. anyways, thanks for the help guys
Old 02-22-2008, 07:14 PM
So do you now know the difference between a fuse and a relay?
Old 02-22-2008, 08:24 PM
cruisen_15's Avatar
Relay: a sort of trigger to allow circuits to connect?
fuse: a metel peice which has currrent flowing through and if the amount of amps that go through exceed the rated amps of that fuse it will blow the circuit.
am i right?
Old 02-23-2008, 05:58 AM
Speedklix's Avatar
Locker Link Solution
...sounds good to me.
Fuses are designed to "give" to protect the electrical system/components, and relays handle various loads.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 02-23-2008, 12:52 PM
kwren's Avatar
not to mention...
Neither do they resemble each other in appearance!
