Old 02-16-2008, 09:47 PM
tubbstcg tubbstcg is offline
Question Interchangeable Parts
I was wondering if there were any interchangeable drive line parts that will work from other subaru models that will work on the svx. I know the 5spd mt will work are there any drive shafts and or differentials that will easily switch out???
Old 02-16-2008, 10:07 PM
Manarius's Avatar
Manarius Manarius is offline
Every post 1990 diff from something other than a Loyale should fit the SVX.
-Jason
-Obi Wan Kenobi
Old 02-16-2008, 10:31 PM
Speedklix's Avatar
Locker Link Solution
there is a list on here just do a search...
I'm pretty sure that my 97 Leg L pads were the same as the svx's... think i added it to the list too.
Most models in the "EJ" line have at least one thing that can be swapped.
4EAT's, brake boosters can be swapped with a bit of help, air filters, check the list.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 02-17-2008, 06:15 AM
Thanks I found the other forum.
