Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 12-07-2007, 02:29 PM
94SubieSVX's Avatar
OOC for a while
I made another mold using just dish soap this time.
Here it is. It's so much better than with saran wrap.
Won't be too much sanding on this mold.
I can't wait to finish the vacuum form "machine" so I can make a lens
bLAh
Old 12-07-2007, 02:44 PM
crazyhorse's Avatar
242,000 mi on oem trans
You'll do SOME sanding. You need to reduce the size by 1/8 on all 4 sides. This will compensate for the thicknes of the Lexan.
"42"
Current Stable By Age:
Old 12-07-2007, 02:49 PM
superru superru is offline
just trying to fix it!
i love it!!! right on the money man!! just make sure you get that plastic hot enough to vac it tight! super job
uhh ya it's a subaru
Old 12-08-2007, 11:40 PM
Roo Roo is offline
Send a message via AIM to Roo Send a message via Yahoo to Roo
Some advice...
I spoke with a TAP Plastics store manager about this project, and he brought up a few things which may/may not help.
1. The lexan, when heated past 212 degrees, becomes VERY moisture prone, and will absorb moisture, which is what causes the bubbling.
2. The lexan may/may not melt, given the temperature of the halogen bulbs and the heat that is created...which is obviously how you're forming these in the first place. If you use thicker Lexan, it would simply retain more heat than thinner Lexan, but would last a bit longer before meltdown occurs.
Again, this is the opinion of a guy who's been doing plastics for some time now, and is only meant for informational purposes. I'd like to see you succeed, and would be happy to purchase a set of these when they become available.
'92 SVX LS-L
Project Car for Open Road Racing
Old 12-09-2007, 03:58 PM
94SubieSVX's Avatar
OOC for a while
Good info. I could get thicker lexan if needed. But I also, have HIDs so the temperature is alot less than normal halogens.
Now that I know the temperature(212 degrees) that lexan gets soft at, I will put it in the oven at 200 degrees for however long I need it to.
bLAh
Old 12-10-2007, 02:25 PM
94SubieSVX's Avatar
OOC for a while
Did some sanding today. There's a couple of small dips that I will fill in later. I just have to make another mold like this but for the other headlight, and I can start molding.
There's a few things left I need to finish up with the vacuum former then it'll be ready to go.
Getting closer to finishing
bLAh
Old 12-10-2007, 05:29 PM
crazyhorse's Avatar
Get some bondo glazing putty to fill the low spots. Then glaze over the whole thing for strength.
"42"
Old 12-10-2007, 05:43 PM
94SubieSVX's Avatar
OOC for a while
I was thinking of using bondo.
It'sJustEric even gave me the idea of making the whole mold out of bondo. It would be super strong but would take forever to make.
bLAh
Old 12-10-2007, 10:25 PM
It's Just Eric's Avatar
Missing in action
lol, no, it'd be faster to make. the trouble is the viscosity....It might be too thick to get the right shape, though, you'r not doing a very complicated shape or anything, so Id say give it a try, even if it';s like, the 3rd try doing it
R.I.P Cool Signature.
Old 12-11-2007, 02:29 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I keep thinking that you will need more vacuum than a you will get from a vacuum cleaner. A vacuum forming machine sucks pretty hard.
If the shop vac doesn't suck it tight enough around the mould, try with a vacuum pump. They seem to go quite cheap on ebay. Have a look at item 350000857210
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 12-11-2007, 05:51 AM
how much HG does that thing suck? for forming we have a pump that does 60 INhg. that's a suckin fool! but we're also doing huge 4'x6' peices. i hope the old shop vac works for you! i'm still kinda busy around the shop here, i hope to try one before the new year.
Old 12-11-2007, 07:09 AM
Roo Roo is offline
Go to your local red-light district and hire someone off the corner...
'92 SVX LS-L
Old 12-11-2007, 07:16 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Make sure you protect the mold
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-11-2007, 10:01 AM
94SubieSVX's Avatar
OOC for a while
Well in a sense it would take longer because I'd have to do a few layers a a time to get into the tight corners, but I know what you mean.
Yeah, I hope the shop vac works, and if not, I'm goin downtown to get someone
bLAh
Old 12-13-2007, 06:59 PM
94SubieSVX's Avatar
OOC for a while
Got a bit done. Here's a few pics of what I did.
Here's the frame holding the lexan in it. Made it just like a video posted earlier in this thread.
Here's the setup. The oven is just out of the picture to the left, close enough that the lexan doesn't get hard once out of the oven.
The first frmae holder setup. I had to raise it about 3 inches more to allow for the sagging lexan.
I had made a 95% perfect mold at first, but two corners weren't up against the plaster mold good enough. So I raised the plaster mold about 1/2" and re-heated the lexan again.
This is what happens if you re-heat the lexan multiple times at about 375degrees and leave it in for too long. It had sagged so much that it started coming out of the frame and was so long that it got wrinkled as you can see.
I'm going to start fresh with a new piece and make sure to watch it before it sags too much.
bLAh
