Old 11-15-2007, 10:48 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
How many O2 sensors do we have
I want to replace mine. I have a '92, not sure if there's a difference between obd1 and 2 svx's.
Brian
Old 11-15-2007, 10:55 AM
NiftySVX NiftySVX is offline
OBD 1 will have 2 sensors, bank one and bank 2. Both are pre cat. OBDII will have 4, bank one and two pre cat and one and two post cat.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 11-15-2007, 11:02 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I thought the OBD-II SVXi only had 3, with the third being the "check" on the two that are mounted before the secondary cats. The third is mounted after the primary cat since it's a two into one cat.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-15-2007, 11:38 AM
SVXride is correct.
OBDII cars have 3 O2 sensors.
One before each pre-cat in the header pipes and the third mounted in the rear of the main cat. This third sensor is mounted in the rear of the cat and installed at the top, where replacement is difficult.
The Magnaflow OBDII replacement 94037 cats have the O2 sensor mounted at the front of the cat (but still at the top, making replacement as difficult) The further back in the exhaust stream you can get, the cleaner the reading will be.
When svxfiles redid my custom exhaust system, we installed the third O2 sensor into the exhaust pipe directly behind the Magnaflow 94007 main cat, which has no O2 sensor bung (this gave us the same cleaner reading as the stock position in the rear of the factory cat itself, but with much easier access in case replacement was necessary.
Old 11-15-2007, 12:33 PM
Ricochet's Avatar
I brought some ham.
Thanks Nifty.
Brian
Old 11-15-2007, 01:22 PM
Guyver280z's Avatar
Guyver280z Guyver280z is offline
Send a message via MSN to Guyver280z
Nice exhaust!
Old 11-15-2007, 05:44 PM
momzsvx's Avatar
momzsvx momzsvx is offline
A mom with style ;-)
Send a message via Yahoo to momzsvx
SVXride is correct.
Are you coming to Ohio anytime soon? Your exhaust looks Awesome!
MOMZSVX
92 LS-L parts
94-LSi My baby
95-(AWD) polo green T-Boned
Old 11-15-2007, 06:23 PM
Ricochet's Avatar
I brought some ham.
They're both covered in oil.. looks to be coming from the front passenger side of the engine. I'm guessing cam seal, just replaced the valve cover gasket. Does anybody have a part number for one of them?
Brian
Old 11-16-2007, 03:31 AM
Ok, so it has three.... I'd forgotten.
The third is to monitor catalyst efficiency.
