Old 10-06-2007, 10:32 PM
914helo 914helo is offline
Igniter?
I've been going through my wiring harness for my EG33 installation (in my Porsche 914) and came across these:
Most of the electrical connections on the harness I don't need: a/c, power steering, tranny, etc. However, if the ecu is sending signals to the igniter then I'm thinking I should have this. Does anybody have a picture of the igniter? Where is it? I thought I had all the pieces I need but I guess not. Thanks
Kent
Old 10-06-2007, 11:05 PM
Greetings Kent,
You will be aware that the igniter constitutes in effect, six solid state relays, which are controlled by the ECU, so as to switch high currents required by the plug mounted ignition coils. It is normally mounted on the engine side of the bulkhead and comprises a quite small enclosure, with opposing multi plug connections.
You certainly must have this component installed.
Old 10-07-2007, 04:06 AM
subarufamily subarufamily is offline
do a search on this site there is a picture of one the=at has green zip ties on it and shows the location, in a picture , for those of us that are not as familiar with our cars as others
