Old 08-24-2007, 12:03 AM
Turbone's Avatar
Turbone Turbone is offline
Send a message via ICQ to Turbone Send a message via AIM to Turbone Send a message via Yahoo to Turbone Send a message via Skype™ to Turbone
Well, it runs and drives. But it likes to stall out on me. It usually happens after about 10min of running. It takes a couple of starts to keep it running and then will be ok. I need to replace the fuel filter, change the oil and filter and the air filter. I'm probably looking at doing the timing belt also. I need to check out the on-line manual, I dont even know if it has one or two belts(DOHC)
Also, when I put the new tail shaft housing on, I forgot to install the new speed senosr I grabbed at the yard. The old one had the attachment piece broken off and theres no way to keep it tight on the housing. So it leaks bad enough to smoke out my cabin and leave a cloud behind me So I get to crawl under the car again and remove a bunch of stuff so I can access it to replace it. I'm getting to know the underside quite well now
Prime Сasual Dating
Old 08-24-2007, 12:07 AM
Rob, the timing belt (one) is so much easier than belts on an EA/ER. With the covers off, I could swap a belt in a few minutes.
A common stalling issue is due to the MAF, but it could be other things. Check for codes, even if it's not showing a CEL.
Old 08-24-2007, 12:14 AM
jeffast jeffast is offline
I kill more trannies then god
+1
timing belt is easy, and its fun to scare people by asking them to pull the pin
scared the crap outta my sis
also yeah i'm here to hi
1991 xt6 eg33?
1993 gc track car
Old 08-24-2007, 11:22 AM
Turbone's Avatar
Originally Posted by jeffast
+1
AH! Theres no escaping
Thanks for the input guys. When I get time, I'll clean the MAF first.
Prime Сasual Dating
Old 08-25-2007, 10:37 AM
Hey Rob,
welcome to the Dark side
The EG33 is a DOHC, but it only has 2 cam belt pulleys, one on each side, the intake cams are gear driven off the exhausht cams, which have the pulley on them.
And yep, just one belt, super easy to time....you'll hate doing a EA/ER after you do the EG
Any questions, don't hesitate to ask....
Old 08-26-2007, 11:42 AM
Turbone's Avatar
Now thats good news. Which makes my week considering I'm also dealing with a engine pull on a friends 91 Galant right now
Had to silicone the speed sensor back onto the case unfortunalty because I found out the Leg sensor is a 3 wire, not 2.
So I'll give my dealer a call on Mon to see if they are still available, along with the ign/key switch.
Prime Сasual Dating
Old 08-26-2007, 12:58 PM
Shadabob's Avatar
Shadabob Shadabob is offline
Liv'n the hobo life
+1, my friend's '92 had a similar issue caused by the MAF.
And your Subaru Hatch= UBAH!
94 SVX LSi, SOLD 01/11
65 Comet Cyclone SOLD
86 BRAT (2x WCSS Award Winner) SOLD
01 Outback (DD)
89 XT-6 Newest Project
Representing Vancouver, WASHINGTON! woot!
Old 08-26-2007, 01:39 PM
Turbone's Avatar
Thanks
I cleaned the MAF and no more stalling issues. BUT, I took it for a spin this morning after my attempt at sealing the speed sensor. Didnt work
Had a pretty good smoke screen going once I got over 40mph.
Hopefully the dealer will have one or be able to order it. Otherwise I will be posting in the Wanted Forum for one. I wonder if the 4EAT on a XT6 is a 2 wire sensor?
Prime Сasual Dating
Old 08-26-2007, 04:43 PM
Welcome to the boards
