Old 04-25-2002, 06:12 PM
92_SVX_LSL
har har har....
my sunroof won't open, it won't open unless you push on it....any ideas?
Old 04-25-2002, 07:02 PM
Green1995SVX
I dont know if you can really fix it. There is a 'clutch adjustment' you can do, but I dont think that will do anything. Just push up on it when you open. Not too much work...
-Mike (no sunroof to worry about here)
Old 04-25-2002, 07:32 PM
sith
Hey mike - I'll bring my dremel to the 10th anniversary meet and we'll add a sunroof for you, ok?
Old 04-25-2002, 09:45 PM
My sunroof wouldn't open very good either. I had to push up on it to get it open, and reach back and mess with it to get it to close. I used silicone spray on the track and around the seals. It opens and closes with ease now. No problems at this time. This might work for you if it isn't the clutch or some other bad thing. Good luck.
Old 04-25-2002, 10:04 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
There is a TSB that addresses the "sticking sunroof" -- it recommends doing exactly what Earl did. I, personally don't like to use spray for fear I'll get it everywhere (I'm a klutz), so, I use a product called sil-glide. It's a silicone lube in a tube. I bought my first tube at Autozone, but, they seem to have discontinued carrying it. Luckily, John Hoffman informed me that they carry it at NAPA stores, and is also available at the NAPA online store.
Randy Johnson
Mike Davis -- at Reading VI
Old 04-25-2002, 10:53 PM
Doogie
I have to push up a little too. It's no big deal though, just put your thumb on the button and use your finger to slightly push up as you push in the button. Nobody even noticed that i'm pushing up on it when i press the button.
Old 04-26-2002, 06:30 AM
EverclearAtMSU
Re: har har har....
I've had this problem on occassion. Usually when it frosts over in the mornings, I'll have issues with it the rest of the day. I found that taking some windex and cleaning the seals around the sunroof helps. I do it everytime I clean my car now. I haven't had a problem since.
