Old 04-09-2007, 11:09 PM
robinhoodof she robinhoodof she is offline
Can't get crank pully off
I want to re time the engine, slipped, but I can't loosen the crank bolt, I think it's a '"lefty loosy". (I ve tried both ways) maybe heat? Any suggestions?
Old 04-09-2007, 11:37 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
If it comes down to it try taking out the radiator and getting an impact gun in there. I wouldn't do the heat idea. It is a lefty, Just holding the engine still is the hard part. I usually stick the handle of my breaker bar under the intake manifold and then use it to block one of the torque converter bolts against the bellhousing to assist in holding the engine still. Good luck.
Old 04-10-2007, 05:00 AM
mikecg's Avatar
mikecg mikecg is offline
Ya, holding the engine is a pain. I almost ran myself over with the 6-speed. Put it in 1st without the e-brake on.
Old 04-10-2007, 05:07 AM
I put a pipe on my breaker bar, and put it on the crank bolt with the handle pointed to the floor just under the battery, and let the pipe go down to touch the floor, then crank the motor over with the key, pops it right loose.
I've never had any trouble using this method, but use at you're own risk.
Old 04-10-2007, 05:09 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
I had the same problem and had to use a heavy duty strap wrench attached to a breaker bar to hold the engine steady. And a 750ftlb impact gun to loosen it. My engine was out of the car so youd probably have to remove the radiator and condensor to do the same.
[SIGPIC][/SIGPIC]
Old 04-10-2007, 05:19 AM
mikecg's Avatar
Thats a little dangerous. Could break a tooth off or damage the starter. Also if he accidently puts it on the wrong side of the car, the bar will smash into his body. Thats one I know I would end up doing.
Old 04-10-2007, 05:26 AM
That's why I said "Under the battery"...and it could be dangerous, but it has always worked for me, and I've never had any trouble doing it....it's an easy simple thing to do when you're working by yourself (which I generally am)
Old 04-11-2007, 07:06 PM
immortal_suby's Avatar
Thread Killah
I've done it a few times with your method also and haven't had a problem. It sounds sketchy but it works well.
Locker Link
2015 BRZ Limited 6MT
Old 04-11-2007, 07:18 PM
I always think about using Huck's method but whenever I get down to it it seems complicated so I get a breaker bar/pipe and a hammer and I karate the thing loose. Takes one good swing. (:
Old 04-12-2007, 02:42 AM
Hop Hop is offline
Classic SVX
I used a strap wrench and a 1/2" ratchet with the handle of my floor jack over it. Whacked the jack handle with a rubber mallet a few times and the bolt came right out. I also sprayed the bolt with liquid wrench and let it sit for a while. I did the cam bolts the same way.
Old 04-12-2007, 08:13 AM
Mr. Pockets's Avatar
Moderator
Moved to Tech Q&A. Please post in the appropriate forum in the future.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-07-2007, 12:06 PM
You made me think of this picture:
Old 06-07-2007, 07:50 PM
Well do you ?!
