Old 03-31-2007, 04:27 AM
Dominus's Avatar
Dominus Dominus is offline
Homo Sapien Superior
Adjuster pulley
I just changed out my alternator and have a feeling the adjuster pulley isn't back to where it should be despite my attempts to return it to where it started. Just how far down the slide (like in inches) is the pulley supposed to be? The Belt seems to have the right amount of tension, but I swear the pulley looks like its further in then when I started. Anyone know?
Old 03-31-2007, 04:50 PM
Psychosis5150's Avatar
Psychosis5150 Psychosis5150 is offline
Yugo aficionado
As long as the belt is routed properly, and tight enough there is no real "right" distance for the tensioner to sit. I wonder if the pulley on the alternator you just put in is the same size as the old one?
Old 03-31-2007, 06:26 PM
Dominus's Avatar
I believe it is the same size. If there is any difference it couldn't be more then a millimeter.
Old 03-31-2007, 06:29 PM
Dominus's Avatar
More
One significant problem though is that I changed the alternator believing it was bad for a number of reasons. One of these reasons was that the warning light, battery light and break warning light would come on intermittently which I was told was a sign the alternator or battery could be bad. I replaced the battery. That did nothing. Now I replaced the alternator and if anything the warning lights are coming on more often. They come on blink maybe three times and disappear.
Old 03-31-2007, 07:03 PM
Yugo aficionado
Mine did pretty much the same thing when the rubber in the crank pulley failed, allowing the outer ring to slip and not drive the accesories. By the time I noticed it the outer ring had almost worn through the timing belt cover, and was working its way off. You might want to take a look at that, other than that I'd check all the electrical connections at the alternator, starter, battery, and ground. Good luck and post what you find, it might help narrow down the problem.
Old 03-31-2007, 08:12 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
the old belt was probably stretched out a bit. as long as the tension is good, then your fine
when putting on a new belt your supposed to run it for awhile and then tighten as needed and then its good to check it again acouple days later just to make sure its still tight. i have to do this everytime i put new strings on my bass, they just stretch.
dustin
-Dustin
Old 03-31-2007, 09:41 PM
SA SVX SA SVX is offline
Another thought may be the voltage regulator. They go in and out before they finally die. Good investment is a battery charger with the alternator check function on it (Walmart $60 or so) gives you a charger and a diagnostic device all is one package.
Dustin, hows the closet coming? LOL
Old 04-01-2007, 04:36 AM
odepaj's Avatar
Killer of threads
haha, its finally clean. but then after that I had to get dirty we just got a new deck on the front of the house so I had to move all the blocks we had laid down as a walk way, and of course its been raining lately so I currently have some lake front property. [/hijack]
dustin
-Dustin
Old 04-02-2007, 11:07 AM
Clydesvx Clydesvx is offline
Way over-the-hill Member
If you got the NEW tensioner from SUBARU you must adjust the belt tension before tightening the tensioner bolt. If you tighten the bolt first the belt tension will not be correct. My warning lights would blink a few times after I put in the new tensioner and started driving. I ignored it until I smelled the belt heating up.
'92 LSL TEAL 277,000 miles
Trans (on # 3) Engine (on # 2)
"NEW" VISORS
'03 Forester XS 214,000 miles
'05 Outback 3.0R
Old 04-02-2007, 12:52 PM
Dominus's Avatar
Wait, I am confused When you say tensioner bolt you mean the bolt that screws it counterclockwise and sits at 1 and 7? If that is correct then I did it the right way. I tightened that bolt first and then tightened the pulley.
Old 04-02-2007, 05:13 PM
Yugo aficionado
Sounds like you did it right
Old 04-03-2007, 08:51 AM
I had a dyslecsic moment. The tensioner I was talking about is on the other side of the engine controlling power steering tension. The alternator is pretty straight forward and it sounds like you got it right. The power steering adjustment is the one that you cant fully tighten until you set the belt tension. The extra drag it put on the engine caused my alternator lights to flicker. Sorry for any confusion.
"NEW" VISORS
'05 Outback 3.0R
Old 04-03-2007, 09:44 AM
Originally Posted by Dominus
...Now I replaced the alternator and if anything the warning lights are coming on more often. They come on blink maybe three times and disappear.
Check the wiring leading to the alternator. After all these years the insulation on most SVX's I've seen has become very brittle. It's possible that you have some exposed wires that make contact when you hit a bump, and thats what is causing the flashing dash lights. Check not only the heavy wire that gets bolted to the alt, but also the two smaller wires that plug into the alternator.
Also a good way to check to see if your crank pulley is slipping is to use a paint pen to make a mark on the face of the pulley. Make a line across all three layers (inner pulley, rubber bushing, outer pulley). If after running the car, those marks move out of alignment, you'll need to replace that pulley.
Old 04-03-2007, 12:15 PM
Mr. Pockets's Avatar
Moderator
I just moved this post from 'babble' to 'tech.'
Please post in the appropriate forum.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-04-2007, 05:30 AM
Dominus's Avatar
Thanks I think I'l try both of these things. If the wires are exposed can I wrap them in eletrical tape to stop them from contacting?
