Old 12-03-2006, 08:52 PM
JoAnn merkur JoAnn merkur is offline
pinkjeans
Send a message via ICQ to JoAnn merkur
here we go again
Okay, listen up, pleaseeeee.
my car was running on 4 cylinders , which they have fixed. But this week it stopped dead on the road, having restarted it with no problem, it ran okay for 2 days. Then the "check engine" light came on, so I took it back to them.
No one can find anything wrong with it. grrrrrrrrrrrrrrrrrr
Have I been cursed !!!!!!!!!!!!
Anyone else had a similar problem?
JoAnn
Old 12-04-2006, 01:22 AM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
carnt say i have, maybe try posting this in the technical Q&A section, maybe someone out there will know
prehaps this may help http://www.subaru-svx.net/forum/showthread.php?t=35851
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 12-04-2006, 04:57 AM
pinkjeans
tku jj
thanks jj , just had a look at site and u r right, others are having same problem.
Old 12-04-2006, 02:21 PM
JoAnn
Hi JoAnn, did they say what the code was, that they got out of the ECU? Should have told them something.
Old 12-04-2006, 09:32 PM
pinkjeans
Unhappy Nothing
HI Harvey,
I told them what all 3 things that should be looked at , which I found from guys on same issue.
MAF , throttle bodies need to be cleaned, and alternator checked.
they have looked at all 3 still can't find a problem.
JoAnn
Old 12-05-2006, 12:00 AM
Dessertrunner's Avatar
JoAnn I had trouble with my wifes 92 and it turned out that when the codes were read they didn't recover the two wires on the drives side under the dash. These wires are used to read the codes and to reset the system if they touch to gether or to ground they will kill the engine. Take the cover off the side were the fuse is under the dash and make sure the two wire with blue cover have the insulation up high enough to cover the bare wire. Good luck.
Tony
Display Modes Rate This Thread
Rate This Thread:
