Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Supercharged Projects
Old 09-21-2006, 09:25 AM
Water Injection Systems
Well, now that my S/C is installed and is a success I am looking to find a decent water injectio system for it. This will not be happening any time soon and probobly not till after winter but I like to look in advance for this kind of stuff. Even running 12lbs this ould be a help to me. List your stuff if you would be so kind
Old 09-21-2006, 10:11 AM
04sti 04sti is offline
Send a message via AIM to 04sti
I was thinking water injection also, but I don't know what brands to trust
Old 09-21-2006, 10:13 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I've got a complete kit that I might just be willing to part with Drop me a PM and I'll give you the specifics.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-21-2006, 12:11 PM
cdigerlando cdigerlando is offline
Water Injection
I'm running a spearco water injection system. It works well. Very simple. Not the best you can get though. I keep getting pushed to run an ethanol mix in it. I may try this at some point.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 09-22-2006, 12:51 PM
Bill is going to hook me up with what he has got so I will see how well it works. Dunno what brand it is but I will find out later Thanks guys
Old 09-23-2006, 11:10 AM
Water injection
Its a pretty basic setup. Pump water to a sprayer. I think any brand will do. You can set it to power the pump at a certain boost pressure, which is what I did, with a pressure switch. Also you should run a line from an area similar in pressure to the point of injection, to compensate for having to boost into a high pressure line. The pressure line boosts the tank pressure. Just make sure your tank is sealed. Also make sure your high tank level is well below the injection point. What you run is up to you. A lot of folks run an ethanol or methanol water mix. I just run water now.
Have fun
Chuck D.
Chuck D.
Old 09-23-2006, 09:32 PM
won't and ethanol mix in the water cause it to become caustic?? therefore slowly desintigrting engine components??
Old 09-23-2006, 10:57 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
i was reading about high compression/ water injection systems. So I was wondering wouldn't it be good to use with lower octane and a minimal jet size. I mean think about it: increase octane, drop temps, and cheaper than premium
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 09-24-2006, 07:10 AM
Maybe but how do you test it?
Chuck D.
Old 09-24-2006, 07:13 AM
Methanol
That is why I won't use it. I have heard that since it is injected and immediately consumed that it does not have that much effect, although this is hearsay. My love for the subaru engine is that it is reliable. I don't want to sacrifice reliablily for performance. I may try it if I have no other choice though.
Chuck D.
