Old 04-14-2006, 05:54 AM
Marcus Marcus is offline
Rage Enduro Rims for SVX, used
I have to sell my set of Rage Enduro Rims. They have OEM dimensions except they use hub centric spacer and different log nuts, which will come together with the rims.
I used the rims with winter tires for two seasons. As they are not approved to be used in Europe, I had to replace them with OEM rims although they are still like new.
I bought the rims for 400$ and I am willing to sell them for 200$, UPS ground will be 25$/rim. Local pic up in Wappingers Falls, NY.
Regards
Marcus
Old 04-14-2006, 08:30 AM
rvnmaniac rvnmaniac is offline
Formerly known as henryrace@hotma
Regards
Marcus
What size, offset and verify color..........
THANKS
HENRY
92 SVX Claret(No More)
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 04-14-2006, 11:49 AM
size / color
Hi Henry!
16X7 5-114.3 40 / Silver
regards
Marcus
PS: I am running the winter tires on remanufactured OEM rims now
Old 04-21-2006, 05:34 PM
dwall25 dwall25 is offline
Rims
Including any tires?
Old 04-23-2006, 05:53 AM
rims only
Hi,
the rims come without tires.
regards
Marcus
Old 04-25-2006, 05:08 AM
Sportcruiser Sportcruiser is offline
Are these still available? I will be in your area May 4 - 7 and may be able to come by and look at them.
What is the purpose of the hub spacer and different lug nuts? Also why are they not approved in Europe?
Thanks,
Steve
Old 04-25-2006, 06:20 AM
purpose of hub spacer etc.
Hi Steve,
the rims are still available. Due to the spacer you can use this rims on several
cars with the same bolt pattern but different hub diameter (e. g. Hondas or Nissans), you just need to have the correct spacer. Naturally I do have the spacer needed on a Subaru SVX.
As you might be able to see in the pictures I attached to my first post, the diameter of the five holes in the rims are not as big as in the OEM rims. Therefore you need to use lug nuts with a smaller outer diameter.
I am glad if I can get rid of them without shipping. So if you are really interested, please write me a message to my private locker. We should be able to figure something out for local pick up...
Regards
Marcus
Old 04-25-2006, 10:11 AM
n00b on demand's Avatar
Darn if you could hold out untill june i could buy them from you. I live here in westchester and you are not far so i could even come and pick them up. Reason for waiting is because im going to florida in the begining of may and money is tight.
Old 04-28-2006, 08:39 AM
hold them till june
Hi,
I did not hear from Steve again and I will be in town next week. So your chances are rising, that they are still waiting for you begin of june.
regards
Marcus
