Go Back   The Subaru SVX World Network > Regional SVX Forum & Clubs > US Regional Forums > Southeast Region
Old 11-26-2005, 02:28 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
Question NEed help agin
Ok well car did not want to start. Found out that it was the fusible link. SO I have to go Bod the builder on the car. Dose anyone know where I can get the stock part. Also does any one know where I can get a lug nut that is 12mm by .0 something? All the auto stores here suck and don't have both parts
pic http://photobucket.com/albums/b329/CrazyJEsus269/?sc=1
Old 11-26-2005, 04:43 PM
Do you need the stock lug nut or a different one?
Old 11-26-2005, 04:47 PM
You can get the fusable link here at Subaruparts.com It is #13 and is $4.41. Good luck.
Old 11-26-2005, 11:47 PM
95pologreen
Ok well I need a different lug nut then the stock one. It has to be 12mm by like .oo something .Also just found out that my tachometer did not want to light up at all. So it was kind of hard driving home.
Old 11-27-2005, 12:59 AM
intelisevil's Avatar
<<<Alcyone
It was hard driving home because your Tach light was out? I'm confused.
I normally worry more about ground speed (speedometer) than engine speed.
Subaru was smart enough to put a rev limiter into the ecu so you really shouldn't need to worry too much . . .
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 11-27-2005, 01:04 PM
95pologreen
Like the dash didn't light up at all like the speedomete. Also the sender dash where the A/C didn't want to light up. The Door lights also. The whole thing that lit up was my headlights and my brake lights. I thinking it might to do something to do with the (Bod the Builder) fuslink that I made. Till the stock one comes in.
Old 11-27-2005, 08:40 PM
95pologreen
Ok well started up the car again and just hanged out in it. Next thing I know is that my headlights started to dim out. So I’m think it is the battery. Here is a pic of the dash with my headlights on link http://photobucket.com/albums/b329/CrazyJEsus269/?sc=1
[IMG] code is Off
