Old 07-17-2005, 11:59 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Bondo questions
The race car has a dent in the rear d. side panel that is rusting. I got it all ready to bondo today and the bondo that I have just peels right off once it hardens. The plan is to bondo it, prime it then cover it with a sticker but any ideas what I might be doing wrong? I've never had such an issue with the crap? Should I get some dif. stuff. I've never heard of the brand that is here, not even sure where or when I got it.
Old 07-17-2005, 12:27 PM
SubaSteevo's Avatar
No longer blue member
Did you sand it down to the metal first?
It's probably just crummy bondo though...
-Steve
01' MSM Lexus IS300
Old 07-17-2005, 12:34 PM
Manarius's Avatar
Manarius Manarius is offline
Having just did bondo, I know all about it :-P.
You're going to need to grind it down to the bare metal, no rust or anything. Also, when you get the bondo on there; 1. Let it go for a while (it does peel off if you don't let it set for a bit) and 2. Cover it with paint or something to keep it from getting battered by the elements (mainly air)
-Jason
-Obi Wan Kenobi
Old 07-17-2005, 12:44 PM
triumph1902's Avatar
triumph1902 triumph1902 is offline
Get different stuff. The stuff you have is probably old and expired or low quality. Also try to pop out the dent as much as possible so the bondo is not on too thick. Before you put it on you should have sanded it to bare metal. After you get it to bare metal, rub the metal with 36 grit paper to get some deep scratches on the metal. Finally blow all the dust off and apply the bondo.
Good luck
Old 07-17-2005, 12:56 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Weight?
I see you are adding weight back to your racer?
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 07-17-2005, 01:20 PM
benebob's Avatar
Thanks guys, I thought I was doing something wrong. I didn't take all the paint off but about 2/3rds as I need it to be small enough of an area that no painting other than priming will be necessary for the time being. The stuff did tell me to prime the bare metal though which I though was odd. Just gonna cover it with a sticker anyways. Currently its drying on a 3rd coat of stuff I just bought.
As for the weight, we probably put a good 200lbs on it this week with the rear dif, driveshaft and axles not to mention the race harness. She's a downright 3000lb pig now! The bondo is on the rear so it is just there for ballast!
Old 07-17-2005, 02:20 PM
Bon't use Bondo, Bondo is made from TALC ( Baby Powder ) and will soak uo water like a spong and the paint will peel a lot better stuff out there. Yes pare metal shinny bare metal
Old 07-17-2005, 03:39 PM
benebob's Avatar
Too late, I usually use fiberglass for repairs but it isn't in a spot that would lend itself to glass nor are there any holes in it. Just basically wanted to fill it and sand it to get the contour back. Remember, it'll get a sticker over it. Fairly certain it'll be quite air tight. We just need a sponsor with a 5.5x12 inch decal to give us some support!
Old 07-17-2005, 06:21 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I used to do body work when I was younger. You always need to sand down to the bare metal and drilling some small holes also helps the filler to hold on better ( the filler goes behind the dent through the holes and acts as an anchore to the body) Use wet sand paper to finish and prime it to protect it before the final coat.
Old 08-11-2005, 05:07 PM
Berlin
Is it right where mine is? I am curious on how you fix it and please post pics when your done.
