Old 06-30-2005, 09:02 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
97 Impreza 2.2l tranny, will it work?
Hey Guys,
I'm talking svxfiles parts guy and he has the 97 impreza 2.2l outback transmissions. Can we use those for our svx's? What gear ratio are they?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-30-2005, 10:57 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Yes, it will work - the gear ratios are 4.11.
My former 4.11 trans was from a 2.2L '96 Impreza Outback Sport.
You'll need a rear diff from a 4.11 Legacy though - the ones from the Impreza are tiny and won't match up to our axles or accomodate the limited-slip hub.
-Chike
2006 Steel Gray WRX TR (sold)
Old 06-30-2005, 09:17 PM
Tim's Avatar
Tim Tim is offline
Thanks I believe I will be placing the order tomorrow
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 07-01-2005, 07:18 AM
svx_commuter's Avatar
Is this a brand new tranmssion?
What other parts have to change?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 07-01-2005, 04:13 PM
Tim's Avatar
Tim Tim is offline
I think the only other thing you need are the seals, screen filter, and pan gasket, as well as gear oil for the rear diff
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 07-01-2005, 05:29 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
would it matter if it's from an obdII car?
Old 07-01-2005, 05:57 PM
lee lee is offline
No, I put a 98 Impreza tranny in a 92 SVX. Works flawless.
Old 07-02-2005, 12:35 AM
Tim-H
It would match up, but with the svx, for a good investment, id be getting some heavy duty sti gears. I've got a legacy manual and after about 30k miles on it the teeth are really singing. Also every time you lay into the pedal your putting a lot of stress on the gear teeth getting this big car moving warping or sharpening the teeth, making them weaker until they wear down or shear off.
Old 07-05-2005, 12:25 AM
Green1995SVX
He is talking about a 4eat. I dont think they put those in the sti
Old 07-05-2005, 09:52 PM
Tim-H
oh i thought he was talking manual swap, i guess i should read deeper. Nevermind
Old 07-06-2005, 06:46 AM
lee lee is offline
Tim,
Been thinking about your post, if the tranny died because of the diff, no issues, but if it died due to failure of internal clutches you might want to get the torque converter to a shop for a rebuild/flush action - I think that will add about $150 to the job, but give you that much piece of mind.
If there's no way financially, I'd run it a few miles with cheap ATF, then drop the pan, change the filter, etc. again.
Old 07-06-2005, 01:10 PM
Hey Chike,
I picked up a 99 imprezza diff with 4.11's in it. it had the bolt on sides for the carrier bearings. This does mean it is a lsd right?? Or am I going to need to swap my carrier??
Old 07-06-2005, 04:04 PM
I don't think the Impreza's had LSD until 2000.
Old 07-06-2005, 08:38 PM
It did have the bolt on sides though, I thought this was an indicator
Old 07-06-2005, 09:01 PM
Chiketkd's Avatar
Tom,
the bolts on the sides are just an indicator that the diff will accept our axles. Earthworm is right, only the '00+ Imprezas had the limited-slip.
-Chike
