Old 06-26-2005, 11:30 PM
GreenMarine's Avatar
From POST-***** to LURKER
Originally Posted by Subafreak
When I put my car up on the lift I can watch the wheels slowly settle down, it's pretty cool.
I do love watching my car do the same thing
Old 06-26-2005, 11:32 PM
Originally Posted by odepaj
!. Odepaj
2. Jnthn_Sctt
3. KCROGUEDOG
anyone else? what would 10% off be? would i get more of a discount if i bought your sway bars at the same time?
dustin
Swaybars?!?!?! Who has them??!?!?!
I WANT!!!! I NEED!!!
Old 06-27-2005, 12:07 AM
WGJ WGJ is offline
I Could Be A Player...
depending upon the time frame and available spring rate. I'm fairly sure I only want to lower the front no more than an inch and the back a half inch.
WGJ
Old 06-27-2005, 10:23 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
WGJ
I would like to do the group order in a month or two (end of july, begining of august at the latest).
The spring rate of Mychailo's springs normally are 185lbs in front and 150lbs in the rear. He can also have custom springs made to your liking. Theres more info on his webpage.
Hopfully you'll be #4, so all we need is one more person.
GreenMarine, Mychailo has swaybars (both front and rear) he has more info about them on his webpage.
dustin
-Dustin
Old 06-27-2005, 10:52 AM
mbtoloczko's Avatar
sans SVX
dustin
Rear bar is still not in production form. I've been slammed with work and yard projects.
The group buy price on the springs would be $350 shipped to anywhere in the lower 48.
Mychailo
Visit my locker
Old 06-30-2005, 06:45 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Okay so last night we finally compared a SVX rear strut to an Impreza rear strut. The differences are the Impreza rear is about 2.5 inches shorter which is about where we'd need it after dieting, the mount for the brake line is different and the hub attachement is a little narrower and the top mount is different. In other words it is totally do able provided we can find the right set up now since there are 1000s of stuff out there. I'm even thinking that a insert like the Koni for the WRX rear would go into the stock SVX housing. I think we just found our cheap (at least for the rear) suspension source to make the SVX racer handle amazingly. I don't think it'll help many on the street as a 2.5 inch drop then the standard drop with aftermarket coil springs would put most of ya under the pothole.
Old 06-30-2005, 06:54 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
!. Odepaj
2. Jnthn_Sctt
3. KCROGUEDOG
4. Te1221
I'd also be interested in the rear sway bar
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-30-2005, 08:48 AM
Guys send me all of your 4 struts over here, i will modify them for you and send them back. It is the best Mod i have done on my SVX !!! even better than the bodykit...
Old 07-01-2005, 12:12 PM
ilsegretosvx
would a Legacy strut be better because its a little longer? Maybe getting a real set of coilovers and using a WRX hub.....Benebob Im looking at the same things
Old 07-01-2005, 12:55 PM
benebob's Avatar
For us definately not as we don't have a whole lot of working room since we're missing 900 lbs and she has the ground clearance of an outback with stock SVX struts currently. As for the hub, I really don't see it being an issue. The SVX one is a tad larger but any machine shop should be able to grind that down if needed. My lazy thought is simply to put WRX koni's in the SVX struts. Should fit fine and with a shorter spring will function just fine.
Old 07-01-2005, 01:05 PM
ilsegretosvx
are the WRX Konis cheaper? Im thinking that either the Tein coilvers or even the JIC FLTs. Do you know the top bolt pattern on the SVX strut top to a WRX?
Old 07-01-2005, 01:09 PM
benebob's Avatar
Cheaper and AVAILABLE besides, if we went to it we just would need the rears as we already have koni's up front.
Assuming you mean the mount bolt pattern. Its totally different.
Old 07-01-2005, 01:13 PM
ilsegretosvx
yep bolt mount pattern. How different. Can the top hats be changed to acomodate a WRX coilover?
Old 07-01-2005, 01:18 PM
benebob's Avatar
Anything can be changed but by going to that expense you'd probably have been better off going with G.C. coilovers.
Old 07-01-2005, 02:00 PM
mbtoloczko's Avatar
sans SVX
The SVX has a different top-hat pattern than other Subarus. But, I suppose its no big deal. Just drill holes in the strut tower where needed.
Mychailo
Visit my locker
