Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 06-21-2005, 05:08 PM
KCROGUEDOG
best lighting
ok one of my silver star light went poop so i disconnected the other one. it is daylight all the time up here so i got some time to replace. my brights are silverstars and still good so i will leave them be. i want really white lights. no blue or other funky colors so what should i get to replace. should i stick with the ss (that im not to much impressed with). or grab up a different brand. the ss brights are kick azz but the normals the shine is not the greatest. oh yeah is there a way of changing out the fogs in the lights with out taking apart whole light?
Old 06-21-2005, 05:11 PM
I like the silver stars in the brights. (9005) I use the modified 9005s in the low beams too because they are projector type, so it is ok. I have used the Sylvania Cool Blues (9005) for those. See the way to modify them in the How-To Documents if you are not familiar with it.
Old 06-21-2005, 05:13 PM
Khalil's Avatar
Khalil Khalil is offline
blah blah, blah.
I have done the 9005 mod with some Cool blues. Very bright.
How hots it getting up there? someone said like 80 deg in fairbanks.
-Khalil
*1992 SVX Red. Now 100k and climbing
Tranny rebuilt @ 84k. Repaint @ 87k.
Mods (in order of install)- K&N air filter, ECUtune stage 1v.4, Alternator mod, removed intake resonator, B&M Supercooler, Window Tint, JDM Emblem, Hid Kit 5000K.
Old 06-21-2005, 05:23 PM
KCROGUEDOG
ensteele u the man ty for the how to. doing this are they going to be to bright? they allow u to see better at night? i really like bright lights u get the looks the svx desirves and less of a chance of get the car all smashed up by a semi. and the weather has been rain rain rain and more rain. boooo but before the ran a week of the 80s. very odd.
Old 06-21-2005, 05:27 PM
KCROGUEDOG
what about the fogs?
Old 06-21-2005, 05:32 PM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
Could someone PM me the how to for the head converson? the dumb thing won't download for me.
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 06-21-2005, 05:46 PM
KCROGUEDOG
the 9005 (brights) bulb u have to shave out the two plastic peices on the inside by the pronges to plug in. with sharp knife or drimle or file. then on the outside of the light to put in socket there are three pieces that stick out to hold the light in place the top one has to be shaved to be thinner to fit. u will see what i mean by trying to put it in normal. then whala sorry if explination sucked.
Old 06-21-2005, 05:47 PM
KCROGUEDOG
u might need to download adobe reader again. the how to is flawless.
Old 06-21-2005, 06:47 PM
rvnmaniac rvnmaniac is offline
Formerly known as henryrace@hotma
How about the reverse lights they suck. What brighter bulbs can be put back there?
HENRY
92 SVX Claret(No More)
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 06-21-2005, 07:19 PM
lee lee is offline
My local Advance Auto Parts carries a 50-watt bulb that fits in the OEM socket. I would be concerned about the adequacy of the wiring if you ever think you'd be in reverse for more than just backing out of a driveway. I have one 50-watt in one back-up lamp, the stock (1156?) in the other - it helped enough that I never went for two of them.
BTW, I have the Cool-Blue 9005 mod and the improvement was incredible. For people who haven't read about this mod before - please be aware this can only safely be used on cars that use a lens to focus the low-beam which the SVX has - to avoid blinding oncoming drivers.
Old 06-21-2005, 09:24 PM
Rotorflyr's Avatar
I plan on doing the 9005 conversion when I get a free moment, have the bulbs, went with the GE Nighthawks (will post a review of em' afterwards), as they were cheaper then the Silverstars (which I put in MrsFlyrs Outback) and also picked up the 9005 socket to splice in, so there's less cutting on the bulb (have heat shrink to cover the wires once spliced in) in the future. Will change the fogs at some point (probably go with the SilverStars for that) and while I never thought about it before, will try the 50watts in the reverse lights (which do indeed suck) at some point.
2006 B9 Tribeca
Old 06-21-2005, 09:47 PM
Take out the liner inside the rear panel. This has small red strips going across the reverse light sections... dims them down a lot. Once removed or cut out, the lights are much brighter. I am thinking of replacing mine with high output lamps as well
Old 06-21-2005, 10:04 PM
KCROGUEDOG
when i took out the strip piece they are hella bright. nothing in the way to stop them. also removed the diffusers. but back to the front im just going to buy the 9005 sstars again and do the mod. the 9005s are bright.
Old 06-21-2005, 11:07 PM
Can't PM it to you. It is doesn't allow for attachments.
Old 06-21-2005, 11:08 PM
I put in 50 watt halogen bulbs and they work like real back up lights.
