Old 06-16-2005, 11:50 PM
1992SVX 1992SVX is offline
Unhappy cv shaft or front diff is blown
parked my car at school for 5 min and come back to move it. i hear and feel the thumping sound from front of my car when its moving. going to go pick it up tomorrow and get it on a lift to figure out whats wrong. had no problems getting to school no unusal noises.
where would i be able to find those parts in northern va, if they need to be replaced. the front diff or cv shaft
would another subraru's cv shaft work instead
1992 pearl svx (given away)
Custom Cold Air Intake
Stage1 Shift Kit
Brembo Cross-Drilled/ Slotted Rotors. Front and Rear
4.44 gears
now in better hands of svxfiles
Old 06-20-2005, 09:46 PM
got my car on a lift today after sitting in the school parking lot for the weekend and found out that my front diff is blown. so i'm going to get rid of the car. unless some one wants it. tell me a price
Stage1 Shift Kit
4.44 gears
Old 06-21-2005, 09:32 PM
is there any place cheap where i can get it done around this area. or can it be done by yourself. u have to remove the transmission right
Stage1 Shift Kit
4.44 gears
Old 06-22-2005, 02:36 PM
Transmission comes out. You'll probably want to source out a 4.11 or 4.44 transmission/rear diff as you'll save money and your car will be more fun to drive.
Old 06-22-2005, 08:20 PM
where would i get 4.11 or 4.44 gears would another subarus work on it
Stage1 Shift Kit
4.44 gears
Old 06-23-2005, 11:47 AM
You are right, those gears come from Subarus that aren't SVX's.
Old 06-23-2005, 01:47 PM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
Mine is also doing the thumping too, but only when I back up. It started when I backed into a parking space that was on a slight incline. Sometimes it will thump, sometimes it won't. Is this the cv joint or the differential?
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 06-23-2005, 02:18 PM
Still sounds like the diff
Old 06-23-2005, 03:51 PM
does sound like the diff because mine did that before it blew up
earthworm: what would need to get. and also do i need to replace transmission
Stage1 Shift Kit
4.44 gears
Old 06-23-2005, 03:54 PM
It's easier to replace the entire transmission since it has to come out anyway. You also need the matching rear diff.
I'm not sure if anything else is needed...ask the guys who have done the swap
Old 06-23-2005, 04:05 PM
who has done the 4.11 swap. what subaru transmission did u use and and rear differential
Stage1 Shift Kit
4.44 gears
Old 06-23-2005, 04:58 PM
Uncamitzi's Avatar
Member #447
Check out my thread "Wish Me Luck"
in the General babble forum.... You may get an answer there...
I'm driving mine again after the front diff detonated.. (ask tom)
Mitch Hansen
"uncamitzi"
This is a Dark Ride
