Well I wrote this in a thread called.' Can I "turn off" the AWD ' back about Jan this year.
"Yes well when they quote the torque split for the VTD, they seem to put it as 40% 60%, instead of the actual 36/64 that it is. Now I suspect that this was, then applied to the Transfer system, the other way around. The Transfer system torque split varies with a number of inputs. Selected gear, road speed, and throttle opening. The split is highest with the lowest gear, the lowest speed and the highest throttle opening. To put this into numbers, when it is in 4th at 30mph/60kph, and you are accelerating hard, the split would be around 60/40, as the road speed rises, the split will reduce to say 75/25. As soon as you lift the foot, the split will reduce to 90/10. When you are taking off hard in 1st, the split is 50/50, as there is a high chance of wheel spin, so the torque split is increased to max. As the speed rises, the split reduces. So mate it is hard to state what the standard split would be, just driving down the road. If you are just cruising, it would be 90/10, hit the throttle to overtake, it would go to say 70/30, lift the foot, back to 90/10. It will allways vary to suit the conditions, though it allways needs some drive to the rear, to prevent the rear drive line from shunting. ". Pretty close to what you have seen. I agree with Beav, 49/51 is not possible. Harvey.
I must agree that more than 50% to the rear wheels would be an impossibility based on the design of the awd 4EAT. In the above info, in MY 'field testing' I never once saw a torque split of 90/10 when cruising along a flat highway at a constant speed. With the shifter in 'D' the torque split always defaulted to 60/40. The harder you accelerated, the split would shift to 50/50; the faster you took a corner, the more the torque would go towards the front wheels on entry at 75/25. -Chike
The SSM is an amazing device that Subaru developed. -Chike
I even bought an awd '93 Legacy TCU just to experiment and noticed a sharp difference in the way it controlled my car. Front wheel spin was definitely easier to come by... Subaru basically developed a specific TCU for the SVX with a greater emphasis towards performance driving... -Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 03-21-2005 at 07:45 PM. |
Since it seams like were only talking voltage to a solonoid would it be thereticly possible to change it manually....namely wiring a potetiometer and just "dailing" the tourqe that you want
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
I think it was Guard-TL who wired up switches to put his trans in three different modes: regular awd, fwd (more like 90/10 or 95/5) and 4wd (50/50). -Chike
A properly functioning Solenoid C will basically 'chatter' on & off incessantly to follow the TCU's commands. -Chike
fixed your post... -Bill
all this info on the auto got me thinking. What is the split for a 91 4.11 legacy mt? Just curious. If anyone knows, let me know.
Tom |
-Chike
-Chike
That is what I heard. Dave |
#28
so the mt's are usually 50/50 like the autos are 60/40? just making sure i understand.
Tom |
#29
non-wrx MTs are 50/50 and any slippage will make that split vary, but the VC diff "tries" to get that 50/50 split back when the VC fluid is stressed and heated. it reacts to any difference in spin between the front and back wheels.
the WRXs are 55/45 IIRC, but react the same way. aside - the AWD system in an auto is arguably "better" since it reacts to the changes in conditions so much faster (electronic sensors vs. heating up a fluid). When a friend of mine took his auto WRX to the Tim O'Neil winter driving school, Tim commented on how much better the auto AWD system felt than the manual.
IggDawg is cool -IggDawg 1992 Teal SVX LS-L 160k miles 4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE 1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k Last edited by IggDawg; 03-22-2005 at 09:27 AM. |
#30
ah, gotcha thnx for the valuable info.
Tom |
