Re: Re: Only useful thread...
-Bill (okay, so I'm done messing with my car...at least for this week ) p.s. Xylene + new knock sensors + other "winter projects" now complete = FUN! p.p.s rear bar end links are next! p.p.p.s You know, I could add a JDM rear spoiler'ed SVX to this mix....
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
On Friday morning before going to work, I'll use a tape measure to gets some specs on my SVX's rear wing. May shed a little light on whether Subaru designed this wing like a upside-down airplane wing??? -Chike
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
-Chike
at speeds over 110 my spoilered 95 seems quite planted to the road, then again it always feels that way so i dunno...
Yea when i had mine at 130 it felt very stirdy and planted to the ground.
That's one of the nicest features of the car. Most cars I've had at 100+MPH give me the feeling of "Oh $h!T if I twitch wrong I'm gonna die!", but the SVX is completely stable at 130. I figure the speed-sensitive steering helps keep it from getting squirrelly, too. Maybe it is the spoiler.
Ok. I am bored here. I should be working on dynamical systems and statistics and probabilities for engineers, but I am not. This lift thing has got me thinking.
So, by my calculations, with a fair amount of error due to graph interpretation and size assumptions, I've determined the downforce to be approximately 37 Newtons (8.4 pounds of force--not to be confused with pounds of mass) at 60mph. Nevertheless, I can improve the accuracy of my calculations with some help. Anyone have the dimensions of the spoiler? I need the length and the distance from the top to bottom so I can find the frontal area.
Eric 1994 Bordeaux Pearl SVX LSi "The SVX — Where, they wondered, do you put the kayak?" |
Also, in the equation, it should be noted that velocity is squared, so the faster you go, the lift gets much greater versus a linear relationship.
Tis true for high speed driving. The faster you drive, the greater the energy needed to overcome the resistance due to air. Also, when I have some more accurate numbers, I will post my work so you guys can look at it.
Perhaps the cross-section of the factory wing does provide a bit of "negative lift" at high speeds, but you'd likely get more downforce on the rear wheels (without the drag) by topping-off your gas tank. Or do what I do: Keep a couple hundred pounds' worth of gear in the trunk. dcb |
#28
I figured I'd post a picture of an airfoil for anyone who isn't familiar...
Basically the air on the top and the bottom split at the front and come together at the back at the same time, but the air over the curved side must travel farther in the same ammount of time as the air on the bottom so it must travel faster, this higher speed produces a lower air pressure and thus lift or downforce depending on what side is curved.
.Karl. Southwest members, click here to check in!CA,NV,AZ,UT,NM,OR,CO Wanted...your busted SVX! Watch out Earl, I'm comin to getchya Return of the Pissed Platypus! X2 My dream (other than a pearlie) 1.8 SVXi and a laguna blue spoiler...somewhere I decided to quit drinking, but I didn't like it so I quit not drinking. |
#29
Apparently, Chris (one of the moderators here) found that above 100mph the spoiler gives about 130 - 150 pounds of downforce. He also said that Chris found this out via some track tests.
Who knows if it's true, but anyone else care to comment? [/B][/QUOTE] Sure. That's why I always try to keep 'er over a hundred in the snow, knowing that the downforce is beneficial in those high speed manuvers around sand trucks. At least that was my explanation to officer Murphy. Now if I can just get him to read these posts, maybe I can avoid slammer time. Ron (Snowjobs R Us).
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
#30
