Old 02-18-2005, 07:41 PM
jb21585's Avatar
jb21585 jb21585 is offline
Does anyone know anything about the EGR?!!
My car is throwing the EGR code and wont start, does the EGR effect the ignition in any way or is it just throwing a random default code? Any advice helps.
Old 02-19-2005, 12:50 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
If the EGR valve is stuck wide open it could make starting difficult. How was the engine running before you last shut it off?
Old 02-19-2005, 01:13 PM
jb21585's Avatar
yeah, it was running fine the night before and the next morning on my way to work it didn't start.
Old 02-19-2005, 01:39 PM
jb21585's Avatar
I also need to know where to find it.
Old 02-20-2005, 01:24 AM
ThetaReactor
Kinda slung up under the intake manifold, on the rear passenger corner.
Old 02-20-2005, 05:35 PM
jb21585's Avatar
thanks, but i got it running
Old 02-23-2005, 02:00 AM
Keister7 Keister7 is offline
Talking tell us what you did!
What happened?
Old 03-03-2005, 06:11 PM
jb21585's Avatar
Well, I had a friend sit in the car and try to start while I was at the Throttle body and while he turned it I gave it a little gas, not much but just enough to get it going, and it ran perfectly fine. I also got a new water temp sensor for the fans and not even a blink of the check engine light.
