Old 02-04-2005, 06:06 AM
Htownsvx Htownsvx is offline
Send a message via Yahoo to Htownsvx
Post coils coils and more coils
ok so i know that i have a bad coils and i think it is coming from the right side put i dont know what piston it is?????
the big Q? has anyone ever changed out the the six coil packs and replacing them with 2 coil pack system like on fords and other american cars.
01 subaru legacy 5sp
97 J-spec kl-ze 5sp ford probe
the best of them all the 92 lsl svx amost 100,000 mile
Old 02-04-2005, 07:12 AM
I prefer changing them all for not risking uneven fire... Even if a couple only need changing. identify the damaged ones, change the whole coils and leave the good used ones as spare...
Old 02-04-2005, 07:36 AM
i don't need to know about the coils>>>>my questionwas>>>>>is it possible or has it ever been done to remove the 6 stock coils, and replace them with standard spark plug wires, and 2 coil packs, like on mustangs and camaro's have been done??????
Old 02-04-2005, 07:54 AM
okkkkkkkkk, sorry for giving a comment about the issue.... now like mustangs and stuff, i dunno...
Old 02-04-2005, 08:20 AM
I have never heard of any one doing that.
Old 02-04-2005, 07:26 PM
mbtoloczko's Avatar
sans SVX
I suppose it could be done, but it would involve rewiring some of the wires going to the coils. I'd think it would be far easier to just replace a bad coil pack, esp since the SVX coil-on-plug design is far superior to any other design wrt to performance.
Mychailo
Visit my locker
Old 02-04-2005, 09:01 PM
THAWA
The aussie's do this when they start making big power. I think they use regular bosch coils the 2 plug ones, a pair of those (though you'd need three), and I dont know what they do to control it. Ask this question on bbs.rslibertyclub.org
Old 02-04-2005, 09:34 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
if you need coil packs contact me i have a complete set or if you only need a few, ready to go.
phil
~Phil
Old 02-05-2005, 05:32 AM
(esp since the SVX coil-on-plug design is far superior to any other design wrt to performance.)
well you are right but that fact of the metter is the the coils are outdated by a good 10 years and a system think the one im talking about will give me more powerfull spark then the svx coil pack with the msd stacker 8. the max voltage on the svx coils is 38,000 and that was tested by msd the pack i wont to put in are 40,000 volt stock
Old 02-05-2005, 07:35 AM
Phast SVX's Avatar
With the SVX's Volumetric efficency nearing 98% what exactly do you think you are gonna gain from more voltage?
phil
~Phil
Old 02-05-2005, 08:22 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I really don't see the point. Has anyone here ever had a misfire problem when there wasn't a spark leakage or bad plug problem? Consider that the waste spark coil fires twice as often and the saturation time is half that of a single coil/cylinder setup. Another consideration is that the coils may have more draw on the primary circuit since the spark is split between two cylinders. This new, higher draw might wreak havoc on the spark controller. I can't tell you how many times I've had to remove Accel Super Coils (or whatever the heck they were called) that some yayhoo had installed because they were frying OE ignition amps. Yup, they may work for a month or two but when you least need it to happen, phhht! there ya are on the side of the road... YMMV
Old 02-05-2005, 08:38 AM
well considering i have one coil pack so far going out, was considering replacing the system with a new either COP MSD system, or a coil pack system with MSD controller, and replace the Control system. Benifits at lower rpm would be good, using a pulse spark offered by the newer MS controller. Plus all this could be put together for alot less than the replacement cost of 6 new coils.
Old 02-05-2005, 09:37 AM
well considering i have one coil pack so far going out, ...
I would just replace the one that is going out and see how thing go from there.
Old 02-05-2005, 09:46 AM
mbtoloczko's Avatar
sans SVX
Even though the SVX design is over 10 years old, its still a state-of-the-art design. There's nothing better than COP.
Which MSD system were you looking at?
Mychailo
Visit my locker
Old 02-05-2005, 12:35 PM
Beav's Avatar
Not as old as Randy
Might I offer that you remove the suspect coil and examine it and the spark plug for signs of spark leakage? Typically coils don't act up intermittently, they normally work or not. Coil insuating boots are a typical problem on our cars, as are cheap (not to be confused with inexpensive) spark plugs. Small lines that appear as pencil marks on the outside of a spark plug are tell-tale as are gray streaks or dots/holes on the side of the coil tubes.
