Old 01-28-2005, 02:47 PM
EddieSVX's Avatar
EddieSVX EddieSVX is offline
shiftin' an automatic
Send a message via AIM to EddieSVX
Angry Brakes...what an expensive pain...
So I guess my front brakes are shot. I'll probably need to replace everything, including calipers.
I'm more than likely going with the Small Car Performance cross-drilled and slotted rotors (all 4 corners), and was wondering if it would be worth it to also get the stainless brake lines they sell. Obviously that's an additional $150 (plus tax, I live in WA), so I want to make sure it's not overkill and not worth the price.
Also, which brake pads do you guys recommend that would be a balance between cost and performance?
http://www.smallcar.com/svx/brakeparts.htm
Eddie
'92 SVX LS-L (For Sale! Info and link to pics... ) #9536 blt. 4/92 (late boomer '92)
'01 Audi S4 (2.7L Twin Turbo - 6MT)
Old 01-28-2005, 04:26 PM
EddieSVX's Avatar
Nevermind my post, I ordered this set instead:
http://www.subaru-svx.net/forum/show...threadid=23598
Got the bore/slot design. I guess Im the first to order that design in the board, since most people are skeptic about it.
We'll see how they perform.
Eddie
Old 01-30-2005, 02:58 PM
kuoh kuoh is offline
Why do you think the calipers are shot? Unless the cylinder or bore were damaged, it shouldn't take much to clean and rebuild.
KuoH
Old 01-31-2005, 08:44 AM
EddieSVX's Avatar
KuoH
You're right, I inspected them this weekend and they were good...
Eddie
Old 01-31-2005, 01:43 PM
I think new seals are only about $20 for all four corners, and it should take a day or less depending on your skills and available tools to clean and rebuild them. Once that's done and you put new pads on, they will be as good as new. Better than new if you get a set of slotted or drilled rotors while you're at it. You were going to spend the money on the calipers anyway.
KuoH
