Old 01-10-2005, 09:29 PM
92SVXMan's Avatar
92SVXMan 92SVXMan is offline
Question Types of steering
I got my 92 SVX lsl about two years ago, and need to know what kind of steering system i have. Is it ESP/S or ECP/S and how do I tell the different?
_______________
92svxman & Freida the co-pilot.
First 92 Claret(flat color,IMHO)
Two 92 Teal(much nicer color)
5 Speed pending, from 93 Legacy Turbo
4.11 Tranny/rear diff. May go for 3.90
Claret 145K
Underdrive Pulley from Newbies2005
New timing belt
new radiator
new water pump
new timing belt cover
New headlights and harness
Replaced exhaust (with stock)
Life on the road who could ask for more
Old 01-11-2005, 05:44 AM
dcarrb dcarrb is offline
The "touring" version (LS-L/LSi) has road speed-sensitive power steering; I believe all others have engine speed-sensitive assist.
dcb
Old 01-11-2005, 09:55 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
dcb
I believe it's just the LS-L (92/3)
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 01-11-2005, 10:22 AM
red95svx
Darrell is right....LSI 's had speed sensitive steering all the way to the 97 M.Y.
92 SVX Man, your 92 LSL has speed sensitive steering, also known as ECP/S
Old 01-11-2005, 05:03 PM
92SVXMan's Avatar
Steering
I will start by Thanking you all for posting Information on steering. Now i must say that my Crankshaft pulley has come apart, looking under the hood I found the Pulley had come off the rubber and moved back to the timing cover. If it was not for bad luck I would not have any luck. Once again Thanks to everyone.
_______________
Claret 145K
New timing belt
new radiator
new water pump
Old 01-13-2005, 11:12 AM
TorG0d
The exact same thing happened to my car not even 2 weeks after I bought it. You need a new harmonic balancer/pulley, cost me about $500 including labor.
Old 01-13-2005, 12:36 PM
Even with labor, five hundred dollars sounds mighty steep. A new crank pulley runs $148.13 + shipping from Subaruparts.com.
dcb
Old 01-13-2005, 12:40 PM
RobSVX
Same thing happened to my 84 Vette. It was actually cutting its way thru the timing cover. If I hadn't caught it... that'd have been bad.
Old 01-13-2005, 01:51 PM
Mr. Pockets's Avatar
Moderator
dcb
Agreed - that should take, what, an hour to replace?
This, by the way, belongs in the Tech Q&A forum.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
