Price of a much need tune up
Hello again
I have been looking to see what a tune up should run me and what type of spark plugs should I have the mech use. also what should they due to her durring the tune up. My mech told me around $350 and it seam a bit high. Some help would be nice. Thanks Chris |
Tune-up is really kind of a misnomer these days. The on-board computer actually 'tunes' the car constantly, if it's functioning correctly.
Typical maintenance would include spark plugs, clean throttle body, change fuel filter, check air filter & pcv valve, clean battery terminals and at the shop I run a 'Quick Comprehensive' test on our diagnostic 'machine'. Book pays 3.4 hours for that. Away from the dealer you'll pay much less, probably. Any brand name spark plug should suffice, just don't get suckered in by Split Fires, etc. If I remember correctly the SVX probably came with single platinum plugs. Here's the factory recommendation: NGK PFR6G-11 or NIPPONDENSO PK20PR-11 . Beav |
Re: Price of a much need tune up
What's up?
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter http://www.ryanmacdonald.com http://www.digitalvertigo.net http://www.open-innovations.com |
Ryan
I know it's been awhile. We should get together for a beer one of these nights. I'll give you a ring.
Later |
good work beav.
i will keep that stuff in mind at 120,000. right now i am at 80,000.
what maintenance should i do over the next 40,000 miles. if you dont mind i would appreciate your recommendation.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
Re: Ryan
Re: good work beav.
Beav |
Nice Randy.
Thread Tools | |
Display Modes | |
