Old 08-21-2004, 06:04 AM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
transmission
is the legacy 4eat the same as the svx 4eat? if not, how does it differ?
Old 08-21-2004, 08:34 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: transmission
From what model year Legacy are we talking?
The mid 90's Legacy 4EATs would be a direct plug-n-play for our cars, but the trans is slightly different from the SVX as there are fewer plates to the clutches. However, with the shorter gearing (i.e. 4.11/4.44 gears) less strain will be put on the trans.
If your trans is on the way out or if you're thinking about adding a little more pep to your SVX, a trans swap would be a good way to go!
-Chike
P.S. One important note, Legacys came with different gearing depending on model and trim level so you'll need to be very careful in selecting a trans. In general, the N/A Legacy sedans came with 4.11 gears, while the turbo Legacy's had 3.90 gears. The Legacy Outabck had 4.44s.
2006 Steel Gray WRX TR (sold)
Old 08-23-2004, 11:21 AM
mark10t
There are some differences between trannys.
Here's a thread that will explain the differences. There are also links to other threads with further explanation.
http://www.subaru-svx.net/forum/show...threadid=19150
I put an SVX transmission in my Legacy Turbo Wagon.
Good Luck.
-Mark
