Old 08-11-2004, 07:15 PM
Bxsvx Bxsvx is offline
How fast is fast?
Send a message via AIM to Bxsvx
lack of cooler flow? I air flushed my cooler and it was clear. My high clutch is burned out at 56k???why meeeeeeeeeeeeeee
Old 08-11-2004, 09:09 PM
n00b on demand's Avatar
I say ya get the solenoids changed and immediatley buy the cooler. I'm getting my cooler soon so looks like we got a little project to do
Old 08-11-2004, 09:48 PM
How fast is fast?
which solenoid pack?
Old 08-11-2004, 10:38 PM
i read that transmission thing you sent me ( lee's guide)....said something about duty solenoid A.
Old 08-12-2004, 07:32 PM
How fast is fast?
bump
Old 08-14-2004, 09:38 PM
How fast is fast?
bumping(school is going to start soon)
Old 08-15-2004, 09:24 AM
bump
Old 08-15-2004, 01:37 PM
Mr. Pockets's Avatar
Moderator
I agree with Harvey - you have classic symptoms of a worn high clutch. You're going to need a rebuilt. Try solenoids and coolers if you want, but you're going to be rebuilding it just the same.
56k miles is pretty early, but that's the SVX for you. When you do put a rebuilt tranny in (and I predict that that's what you're headed for), put in an aftermarket cooler. The SVX's tranny is fine - it's not 'weak' or 'problematic.' It was just not provided with sufficient cooling by Subaru.
Sorry, but I think a rebuild is the only thing you're in for.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 08-18-2004, 04:29 PM
How fast is fast?
Thank Mr. Pockets for the info, I might be looking into converting it to awd and putting a manual conversion, let see what the future holds for me. I did notice something weird, I was driving the car around the block, and it started slipping, so I pressed the gas a little for the power light to come on and it caught 3rd gear right away, I couldnt shift to 4th because I had no more street left, I had to brake, anyone have experience with this?
Old 08-19-2004, 10:55 AM
Moderator
I would call that normal for a worn clutch. Slips under low pressures, still grabs okay under higher pressures. Don't worry - it won't grab in either situation soon enough.
2005 Outback
END OF LINE
Old 08-19-2004, 11:17 AM
How fast is fast?
But, I dont understand, I pressed the gas just for the light to come on, the rpms never went over 3k.
Old 08-19-2004, 11:29 AM
And you smile because?
Old 08-19-2004, 02:14 PM
Moderator
As I understand it, 'power' mode affects not only the shift points but also the hydraulic pressure used to shift.
2005 Outback
END OF LINE
Old 08-19-2004, 02:16 PM
Moderator
Because I enjoy making fun of people in unfortunate circumstances.
Of course not.
I was, however, making a little light of the situation.
2005 Outback
END OF LINE
Old 08-19-2004, 03:06 PM
Of course not.
All this tranny failing stuff sucks. And it sucks that it happened for him at 56 K. Why could it have happened to early and the rest of us have fine tranny's? Thats what i dont get.
