Now if you could shut of the injector along with the spark and have the valves open (it would only work on an non-interferance engine) so that you aren't generating any compression then I think it would work. Just my $.02. ~Ray
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
I also fixed that problem by disconnecting my resistor. Since I leave my shifter in 'D' all the time, I get none of the jerkiness on decel. I love the firm, brisk shifts from this free mod!
-Chike Quote:
a little tangent...
Chike, Do you find that the unplugged resistor gives *really* rough shifts at low speed? I didn't leave mine unplugged for long, maybe I didn't give the ECU enough time to get used to it...
-Mike '92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91 "It says here, 'Breakfast any time'... That's right... In that case, I'll have the pancakes in the Age of Enlightenment..." |
Re: a little tangent...
No rough shifts here. If I move the gear selector into '3' or '2' the shifts become very rough on decel - however, I always leave my selector in 'D' and haven't noticed any 'roughness' at low speeds...
-Chike Quote:
With the final drive in the SVXs a little turbo diesel would be perfect, and with todays technology it would still be quick Remember to look at torque on a diesel, not HP...
.Karl. Southwest members, click here to check in!CA,NV,AZ,UT,NM,OR,CO Wanted...your busted SVX! Watch out Earl, I'm comin to getchya Return of the Pissed Platypus! X2 My dream (other than a pearlie) 1.8 SVXi and a laguna blue spoiler...somewhere I decided to quit drinking, but I didn't like it so I quit not drinking. |
I just have to put my thoughts inthis thread.
WATER
The problem with killing a few cylinders to save fuel is that reducing the effective displacement doesn't reduce the amount of energy required to move the car. For any given amount of work to be done, the amount of fuel required will be [almost] the same, regardless of how many cylinders you use.
Killing the spark alone will reduce economy considerably because you're still using fuel, but wasting it. Killing the fuel injectors may have a small effect, good or bad, but trivial either way. Disabling the intake and exhaust valves and killing the fuel injectors may have some useful effect at improving economy. If the valves allow air to travel in and out of the cylinders, this will effectively act like a Jake Brake, reducing economy. By closing the valves, the air inside those cylinders is simply compressed, (consuming energy like a spring,) and then decompressed, (releasing energy like a spring,) over and over again. Smaller engines are usually more efficient because they operate near peak capacity more often, i.e., they are "in the zone" most of the time. Also, there are fewer moving parts. Ever try to crank an engine over by hand? It's a lot of work. Imagine how much work it takes to do that at 3000 RPM! Yes, in theory you could realize a small fuel savings, but there is a reason manufacturers don't use these techniques on modern car engines; They don't work. ...at least well enough to be worth it. |
If you want gas mileage get a hybrid The whole purpose of the cutting cylinders is to be less harsh on the trans during the 1-2 shift. Listen to it at a WOT 1-2 shift. Especially with my exhaust it sounds alot different than other shifts (2-3 3-4)...
Such an advanced ECU and yet the weakest link is still this transmission.
1995 850Ci 1988 Prelude~ B20 swap 2006 Mustang GT (RIP) |
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock |
Guys in my car I have a system... I was wondering of. When I am cruising on the highway on D, I reach a point where I can feel the RPM's go down because of a shift in my tranny even though I am cruising on D. it's like Overdrive, or Super Overdrive something... I dunno if this is a special feature in my Gulf specs car or it is normal to do that. ??
it's like I reach a point where I am cruising at 100 km/h with an rpm of 1900 ! Consumption becomes verrrrrrrrrrrrrrrrrrrrrrrrrrrry low. Am I using 3 cylinders out of 6 ? I really need some documentary about the specs of the Gulfian SVX's
#29
#30
isn't there a limp home feature that does the same thing for an extended amount of time? It would seem easier to find that and put a switch to it than to isolate that moment in a shift.
Granted the odds of it actually helping are slim, but, I think the only way to find out for sure is for somebody other than myself to try it. Skip
'95 SVX L - Laguna blue 126,000+ miles '89 XT - some sort of sun bleached blue '00 Hyundai Sonata- charcoal gray (hers) |
