Old 08-04-2004, 06:27 AM
A-Train
Spark Plugs
Question? What is the best plugs on the market for the SVX, had recent major tune up and requested boush +4's gas mileage has improved and SVX is much more responsive. Also while I'm at it what about the oil, whats being used.
Old 08-04-2004, 08:25 AM
Beldin
Re: Spark Plugs
I say the stock NGK's are by far the best. Those Bausch +4's are just a good way to damage your engine.
And engine oil, if you don't have any leaks, go with a fully synthetic like Mobil 1.
Old 08-04-2004, 08:29 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: Re: Spark Plugs
I agree with Beldin - the stock NGK's are by far the best buy. Check out this thread A-Train: Which Spark Plugs?
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-04-2004, 09:21 AM
A-Train
Spark Plugs
Thanks Beldin, and Chiketkd for your info and direction, you said "DAMAGE MY ENGINE"!!!!!!!!!!??????? the plugs will be removed this weekend, stock plugs will go in. Longassname did do a good job explaining differience in plugs.
Old 08-04-2004, 10:05 AM
Chiketkd's Avatar
Re: Spark Plugs
No prob. As you saw from that linked thread, a lot of people use Bosch +4's in their SVXs (from poll), however, like you mentioned, Longass explained the differences in sparkplugs very well...
Good luck!
-Chike
P.S. Our Stock Platinum NGK plugs are ones that other car owners upgrade to. These are really good spark plugs!!!
Old 08-04-2004, 10:31 AM
mbtoloczko's Avatar
sans SVX
One item to keep an eye out for are the Denso "Iridium Tough" spark plugs which are not yet available in the USA. Same 0.4 mm dia tip, but with a platinum chip on the ground arch.
http://www.denso.co.jp/PLUG/iridiumtough/index.html
Actually, if anyone is interested, I can look into ordering these plugs from my contact in Japan.
Mychailo
Visit my locker
