Old 07-28-2004, 03:42 PM
simonton
power steering pump
is there any difference between a power steering pump in a 92 ls-l and a 94 lsi?
if not, how difficult is removal and installation? I've got an amazing service manual that's 4 books long with detailed instruction
Old 07-28-2004, 03:54 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: power steering pump
Someone will correct me if I'm wrong, but, I don't think so.
Oh, and installation is pretty straight forward.
Randy Johnson
Mike Davis -- at Reading VI
Old 07-28-2004, 03:56 PM
Mr. Pockets's Avatar
Moderator
Between those trim levels, Randy's right, the pumps should be the same.
And it sounds to me like you have the factory serice manuals (FSMs), so installation should be cake.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-28-2004, 04:03 PM
Aredubjay's Avatar
Hmmm. After checking subaruparts.com, the diagrams are a bit confusing.
I'll report. You decide.
This is the 92
http://www.subaruparts.com/diag/?mod...ategory=346-A1
This is the 94
http://www.subaruparts.com/diag/?mod...category=346-1
On the 94, it lists an entire pump assembly
http://www.subaruparts.com/diag/?mod...category=348-1
Randy Johnson
Old 07-28-2004, 05:01 PM
nitrosvx
the only diffrence is if its got a sunroof or not
Old 07-29-2004, 09:14 AM
Aredubjay's Avatar
Simplified, but, true. The sun roof indicates an LS-L designation which would require the pump for the electronic speed sensing rack. The "other" alternative on the "lesser" models is a pump geared to engine revolution and is not electronically controlled. Here are the part numbers for each:
http://www.subaruparts.com/diag/?mo...&category=347-B
Part # 34110PA030
Engine rev controlled.
34110PA010
Randy Johnson
Old 07-29-2004, 12:10 PM
red95svx
Yes, the pumps will be the same. They only made two types: one for vehicle speed sensitive (AKA electronic control), and one for RPM speed sensitive. As long as you install a pump from a car that has the same type of steering system that your does, you'll be fine. LSL and LSI models used the same pumps.
