Old 07-22-2004, 08:09 PM
JeffN JeffN is offline
Speedo gear
Anyone ever change their speedo gear in their trans? Are they available? I want to go to a pre 97 tire size and want the correct input to the speedo from the diameter change. thanks
Old 07-23-2004, 02:43 PM
red95svx
The speedo gears were the same for all SVX's. Subaru compensated for the 97's different tire size by reprogramming the ECU.
Old 07-23-2004, 03:14 PM
alltrac alltrac is offline
I found this tire calculator someone tell me if I put a 97 ecu in my 96 will I have a higher top speed? with my stock 225-50-16 tires.
Victor
Old 07-23-2004, 04:02 PM
lee lee is offline
the top speed is horsepower/drag limited. A change of 1.8% difference in tire height will not have a measurable effect on top speed. Going from a 215/55 to a 225/16 will yield a tiny bit more acceleration due to the reduced tire diameter, but even this is probably a value that would be two or more decimal places difference in the 1/4 mile (my guess anyway). Said another way going from a 215/55 to a 225/50 is the same as changing from the stock 3.545 gearing to a 3.607 and keeping the same tire - not much change.
Old 07-23-2004, 05:34 PM
How'd you get those #'s?
Embarrass me if you will. My calc's are:
225x2x.5=225mm/25.4=8.86".
215x2x.55=236.5mm/9.31".
8.86/9.31=0.95 or about 5% change in diameter.
9.31-8.86=0.45"x3.17=1.43"/revolution. So what the hell am I saying? I think it's a 5% change in circumference so 60mph on the speedo is a real 57mph. Maybe my long division became wrong division somewhere.
Old 07-23-2004, 06:55 PM
lee lee is offline
I measured a ratio of wheel/tire diameters (and I think you forgot to include the wheel).
using your numbers 8.86+16=24.86, and 9.31+16=25.31 and 25.31/24.86=1.018 or .018 increase, which when multiplied by 100 yields 1.8% over a 1 to 1 ratio.
if you want to do it in circumference then the numbers top & bottom get multiplied by pi each to yield 79.51/78.10=1.018.
At any rate, the top speed is not attained at redline in high gear, the car can't push hard enough. The R&T coverage of the SVX shows top speed obtained at slightly less than 5K rpm in top gear before the car runs out of steam.
Old 07-23-2004, 08:39 PM
Yep, and the piddling diference in the speedo/odo pales compared to driving it which it's all about.
