is it the belts????
Alright, here's the deal, whenever i'm idling i hear a squeling from under the hood. I'm assuming it's the belt. I just had all of the belts replaced less then a year ago, and the noise just starting the other day. It only does it when i am not excelerating. If i touch the gas at all, it stops. What do i do? and should i be worried????
~Jamie 92 SVX Ls pearlie |
1. Check both belts (A/C and PS) to see if they are cracked or worn.
2. Make sure both belts are tightened correctly. 3. Try to locate the source of the sound, could be that a bearing in one of the pulleys is going/went.
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
The AC electric clutch will make that noise when it is going out as well.
entire A/C system was just replaced last year too. Although is has only been 1 year since i replaced the belts, i have put 30k miles on the car, so i wouldn't doubt that that's what it is...thanks for ya'lls help
try adding some power steering fluid...i had this squealing noise thats the same as yours and it went away after i added some fluid. Weird fix i know but hey it worked.
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
dcb |
Also check if the crank pulley hasn't separated and causing the noise. Are the belts dry/clean?
yeah, everything under my hood is clean, i get bored and clean my car at random. As far is being dry, i have no clue, i'm thinking its a pulley, but i'm going to take it in in the next couple days. thx!
This may sound silly to some, but even something as simple as the brand of belt may be to blame - not all belts are created equally.
I've found that the DAYCO belts on my '62 Corvair are more likely to get thrown off the pulleys then any other brand (they're actually a tiny bit wider & don't sit in the groove as well). The Dayco's would also shread on my last car, a Dodge Stealth, where all pulleys checked fine. Could easily be a similar issue here. Dayco's are usually in a black/grey package Kelley-Springfield in a green/white package not sure about the other brands. Hope it helps. ~Brenda |
