code #34 help
Does anybody know what part throws a trouble code #34 EGR Solenoid Valve Inoperative. http://www.subaruparts.com/diag/?mod...category=081-A
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
I would suggest resetting the ecu and seeing if the code pops up again. I've had that code once before. Reset and it never came back. Its always good to make sure before you start spending money
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock |
I tried that and it keeps coming back.
I would say then, it is either item one or seven. There is a way to physically check if the valve is working properly, but I forget how. Hopefully someone else will chime in...
Code 34, EGR.
If the ECU has set a code, then it has to be the EGR solenoid that turns the EGR valve, on and off. That is the only thing that the ECU would know about.
It is located, er, um, don't know. Harvey.
Thread Tools | |
Display Modes | |
