Old 05-07-2004, 10:21 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Squealing
I have a squealing sound coming from the passenger front of my car. The car has a steering wheel shudder and vibration at speeds.
First I thought it was from the bad ball joint, so I changed that. Nope. Then I thought it might be brakes, but the sound is present whether or not the pedal is depressed.
My next thought is cv joint. I really can't imagine what else it might be. Any thoughts?
Thanks in advance.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-07-2004, 11:15 AM
dcarrb dcarrb is offline
Angry power steering.
dcb
Old 05-07-2004, 11:23 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
My $0.02. It could possibly be:
1) a loose belt
2) a brake caliper that has seized and is permanently rubbing against the rotor
3) your imagination!
2006 Steel Gray WRX TR (sold)
Old 05-07-2004, 10:00 PM
Word to Yo Motha
Pretty sure its not a caliper, not rubbing all the time. Just an intermittent squeal. I know its not a belt, only while moving. Not steering related. I am going to do the cv axle tomorrow, hopefully that fixes my problem.
Collin
1995 L AWD
Locker
Old 05-08-2004, 11:05 AM
Chiketkd's Avatar
Question: does the squealing only happen when you have the A/C on?
You said it came from the front of the car on the passenger side - which is where the A/C compressor and its drive belt are located. My wife's old 240SX had a loose A/C belt and it would squeal at times when you stepped on the gas.
Just a thought...
-Chike
Old 05-09-2004, 06:08 PM
Word to Yo Motha
Just a thought...
-Chike
I wish it was the ac...
Pretty sure it is the cv though. I've had a couple of people ride in the car this weekend and we all came to the same conclusion. Now I just need to order some parts so I can do it next weekend.
Collin
1995 L AWD
Locker
Old 05-10-2004, 09:59 AM
96svxer
I had a high pitched squeel comming from my tires. Turned out it was a defective brake pad. (They were only about a month old) They looked fine, but as soon as I swapped in the old brake pads the noise instantly went away. Might want to try that?
PS the squeel was always on, not just when the brakes were pressed..
Old 05-10-2004, 10:37 AM
Word to Yo Motha
I might give that a try. I'm going to change the cv anyway. Due to the vibrations I'm getting on the highway I think it is time. Also, at 110k it doesn't hurt to start changing things.
If I still have the squeal after that, I'll take a look at the brakes. Thanks.
Collin
1995 L AWD
Locker
Old 05-16-2004, 08:25 PM
Word to Yo Motha
Well, replaced the cv this weekend with one from Raxles. All I can say is WOW! It is amazing how well the car drives now. It actually fixed some problems I was having that I thought completely unrelated.
The install was fairly simple. I would've been done in less than a 1/2 hour, but the GD pin wouldn't fit in. That took me quite a while to convince it to go in place. I am very happy with the result, it was well worth it.
I paid a bit extra for the Raxles part, but it was very high quality. I was very impressed.
Collin
1995 L AWD
Locker
Old 05-16-2004, 10:55 PM
deruvian
What kind of vibrations were you having? I've always had a strange feeling that I should replace them, but haven't seen a reason to after inspecting. I do get some vibrating on the freeway and especially right around 50mph.
Old 05-17-2004, 07:10 AM
Word to Yo Motha
I was having vibrations anytime I turned left, more noticeable at highway speeds. The right side joint was bad. The biggest flag for a bad CV is clunking coming from that area when you put it into gear or accelerate from a stand-still. You can also check them by making slow, tight circles in a parking lot. You will hear clicking/clunking from the side opposite the turn if it is bad.
I found why it was squealing too. When I went to take the axle nut off, it was HAND TIGHT!!!! I was lucky that there was no bearing damage. Doubt you will have that problem though. I have a feeling it was due to bad service.
Collin
1995 L AWD
Locker
