Old 05-05-2004, 11:17 AM
TorG0d
brake light - stupid question
My brake light came on while driving to work this morning. My parking brake is fully off and the fluid level is fine. What else could this be? The light won't turn off when the car is on. Thanks.
Old 05-05-2004, 11:20 AM
SVX-Utah
Is it the brake lamp light or the actual brake light that goes on when you pull up on your e-brake?
Old 05-05-2004, 11:43 AM
TorG0d
The in-dash brake light is the light that comes on. Sorry for not being clearer on that. I just tested my ABS and that seems to be working fine. Could my fluid sensor have gone out? If so, how might I test that?
Old 05-05-2004, 12:46 PM
SVX-Utah
I have had the problem of the switch on the hand brake coming loose enough to trigger the dash Brake light even when brake is all the way off.
I have also had poor connections in my tail brake lights that will trigger the brake Lamp light on the dash
2 lights 2 mysteries 1 answer
Tinker till it stops lol
sorry cant be of further help on this one
good luck
Old 05-05-2004, 12:56 PM
lee lee is offline
sorry if this seems dumb, but have you physically checked the brake lights? If one is burnt out the dash brake light comes on.
Old 05-05-2004, 01:13 PM
n00b on demand's Avatar
the same thing happened to me in the winter time. the fluid level was fine and everything else was running fine. the in dash brake light wouldnt turn off at all. i even restarted the engine about 4 times to see if it would go off but no luck. what i ended up doing was opening the brake fluis cap to check the level and then as soon as i closed the cap the light went off.
Old 05-09-2004, 11:10 AM
TorG0d
I opened the brake fluid reservior, closed it, and the light went away. Thanks. I still have some hair left . . .
Old 05-09-2004, 03:12 PM
deruvian
That is by far the strangest fix that I have ever heard of.
Old 05-09-2004, 04:56 PM
if you didnt know by now....everyone with an SVX has a strange fix for certain problems
Old 05-10-2004, 09:43 AM
Mr. Pockets's Avatar
Moderator
Isn't there a separate idiot light for that, though? I thought there was a 'Stop Lamp' light to tell you when a brake light was out.
As I understand it, if both brake lights on one side go out, that light won't come on...go figure
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
