Old 04-30-2004, 11:11 PM
my scientific tranny temp study
ok, so i removed my belly pan today and replaced the insulation (aluminum-backed foam tape) around my temp sender. tranny cooler is TCI brand. the temp sender is incorporated into a Permacool external filter, which is mounted to the panel below the battery. the gauge used is a Nordskog digital. outside temps used were taken from the outside temp display on the climate control head. air conditioning on both days. i was keeping notes on the tranny temps driving to work yesterday and today (3:30PM, heavy stop-n-go traffic, several hills). here's the results:
YESTERDAY - undertray on, no insultion on temp sender
outside temp: 83degF
max tranny temp: 212degF average cruising temp: 195-ish
TODAY - undertray removed, insulated temp sender
outside temp: 82degF
max tranny temp: 189degF average cruising temp: 175-ish
TONIGHT - " " (return home - same route, less traffic, no AC)
outside temp: 64degF
max tranny temp: 177degF average cruising temp: 170-ish
the temp gets scrubbed off much quicker without the undertray as well. cools down noticeably quicker on a flat or downhill stretch of road. now i'm off to conduct a study on the reaction of beer and nachos in my stomach.
Alan (Mr. Science)
Old 05-01-2004, 08:59 AM
mbtoloczko's Avatar
sans SVX
I've seen similar temp drops with the belly pan removed. It seems like its a good idea to remove it in the summer months. I wonder how it allows more effective cooling.
Mychailo
Visit my locker
Old 05-01-2004, 01:22 PM
deruvian
I'd remove the belly pan, but I'm sort of paranoid about something flying up and denting or breaking my oil pan, or causing a coolant line to pop off. I do live in an area where driving in gravel is somewhat of a common occurence.
Old 05-01-2004, 04:46 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Originally posted by deruvian
I'd remove the belly pan, but I'm sort of paranoid about something flying up and denting or breaking my oil pan, or causing a coolant line to pop off. I do live in an area where driving in gravel is somewhat of a common occurrence.
There are not many cars on the road, past or present, that have any type of under engine protection like our cars. I am sure you will not have any of the above mentioned problems.
Unless you are planning to do some serious off roading.
I keep mine off all summer and have not had any problems.
Old 05-01-2004, 05:35 PM
Must do test.
Alan how about doing another test, to compare the temps that occure using Drive for one, and another run using 3rd, to see if there is a difference in temps.
Same conditions. just 4th vers 3rd.
Old 05-01-2004, 09:28 PM
Snickers
When you say belly pan do you mean the partial shroud that starts under the radiator? Are you friggin' kiddin' me? This simple 'mod' can lower the tranny temp by 20 degrees? If so, this should be the #1 mod of all time. Are there any drawbacks?
Old 05-01-2004, 09:35 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
I also would like to know where the belly pan is exactly...
2006 Steel Gray WRX TR (sold)
Old 05-02-2004, 01:03 AM
immortal_suby's Avatar
Thread Killah
The belly pan is the big plastic thing under the front of the car.
Locker Link
2015 BRZ Limited 6MT
Old 05-02-2004, 02:05 AM
Green1995SVX
I removed my belly pan back when I had the auto, and it lowered tranny temps by about 20 degrees. It did, though, significantly increase the amount of road 'dust' that got into the engine bay. I found myself having to dust the engine bay and re-apply protectant to all of the black stuff once a week to keep it looking nice under there.
Mike
Old 05-02-2004, 08:30 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
My belly pan "fell off" about 6 months ago. I use quotes because it was really taken off by breaking the bolts by a dealership, but I didn't notice for a little while. When I asked them about it they said it must have fell off.
Anyway, back to the topic at hand, I have driven the car like this for some time. It has even been in snows over 1 foot with no problem. I don't plan on replacing it anytime soon.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-02-2004, 12:35 PM
Alan (Mr. Science)
I was wondering what the effect would be in insulating the temp sender. If that is giving you a different reading than if it was not put on. That is something to consider. If it was on at the start of the experiment, it would show what happened when everything is the same. Maybe take the tape off (insulation) and see what happens. Does it increase the temp reading, or stay the same.
Old 05-02-2004, 02:03 PM
Re: Must do test.
that's a good idea, Harvey - i was thinking about doing that, too. i forgot to mention i also have the smallcar shiftkit installed, and its at the default setting. probably not a big effect on temps, but a little i'm sure.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 05-02-2004, 02:08 PM
Originally posted by ensteele
Alan (Mr. Science)
i wish i had time to test all these different factors - i'll try to do it if i get a chance. the bellypan definitely affects cooldown time when the fluid does get hot. with the bellypan on, it never seems to drop - only increase. it will cool off quicker with no bellypan.
the bottom line is, no bellypan (and an insulated sender, if you have a gauge) will result in lower temps and more accurate readings on your gauge.
Old 05-02-2004, 02:10 PM
Why would the insulated sender give you lower temps? Or would it just give you a reading that is more true than without?
Old 05-02-2004, 02:36 PM
it wouldn't actually lower the temp, but it would give you a more accurate reading without all the ambient heat from the engine affecting it. our boxers kick out the heat!
