Old 10-16-2001, 12:09 PM
Mr.Pwrlite's Avatar
Mr.Pwrlite Mr.Pwrlite is offline
Originally posted by huck369
Deffinately sounds like a front crank seal, it's about a $8.00 dollar part, but you have to remove the timing belt to get to it, so replacing the timing belt at the same time saves labor costs, if it has several miles on the motor, you might want to replace the water pump as it would be easily done while everything else is off.
Huck, You're 100% in the right direction, I've been through the same situation. Shadow, If this is a job that you plan to do yourself, look for it to be a good few hours work. It's really not a hard job , just a little time consuming in some areas. Also take caution loosening the bolts in the timing belt covers, The covers are very brittle. I know Good Luck!
"If it works, tear it apart and find out why!...... "
94 Blue L, 5-speed, converted 4wd, Clear headlights, Angel Eyes, Converted Radiator and fan, White faced guages, Cross-drilled/slotted rotors, Lambo doors ...
