Old 10-07-2001, 12:37 PM
ehyde111
Question chenged oil, now reads too full
I had my 92 svx up on the ramps yesterday and changed the oil and filter. Put 6 quarts in, backed off the ramps and filled up to a bit below the full mark. One day later (today) I rechecked the level (to make sure I don't have any leaks etc) and found the engine oil level now reads about 1/4 inch ABOVE the full mark. Silly quesiton, but should I let some out? That just seems like a pain and a real mess. Will the metal gasket that comes along with the OEM filter still work if I loosen the pan drain plug to let some oil out and then re-tighten? How bad is it to have this much more oil in?
Thanks
Old 10-07-2001, 02:16 PM
dromano's Avatar
dromano dromano is offline
Chris, if you put in 6.3 quarts you need not worry. When I do an oil change 6.3 quarts leaves a mark half way between 'L' & 'F'.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 10-07-2001, 02:38 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Chris, don't worry about it. It's not too over full to matter if it's just a quarter inch over full.
Randy Johnson
Mike Davis -- at Reading VI
Old 10-07-2001, 06:47 PM
nvrmore100's Avatar
nvrmore100 nvrmore100 is offline
Send a message via AIM to nvrmore100 Send a message via Yahoo to nvrmore100
Re: chenged oil, now reads too full
Thanks
Agreed sounds like you didn't completely overfill it. On a second note though, its easier to remove your filter to get a little bit of oil out. It tends to be less messy.
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter
http://www.ryanmacdonald.com
http://www.digitalvertigo.net
http://www.open-innovations.com
Old 10-07-2001, 07:48 PM
ehyde111
Thumbs up Re: Re: chenged oil, now reads too full
That's a good throught. I don't have to worry about the metal gasket on the drain plug then and I know I won't loose too much oil. I don't think I'll get to it tonight, but that will be on the list for tomorrow afternoon.
Thanks
